Re: TMC 2100 and ramps - any pitfalls to avoid? February 22, 2017 03:06AM |
make sure you don't have a faulty ramps with traces joining them (this is only a problem if you do the CFG 1 to GND bridge)
Re: TMC 2100 and ramps - any pitfalls to avoid? February 22, 2017 10:22AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 22, 2017 10:55AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 22, 2017 02:06PM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 23, 2017 10:53AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 23, 2017 11:11AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 23, 2017 11:46AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 23, 2017 01:36PM |
GroupB
Probably that lack of torque thing I was talking about... I hear you can set them close to they peak rating and the controller will up and down the current when needed ( smart current control) but do some searching before I only "hear" this im not 100% sure. They probably not good enough for corexy Z because of this or direct extruder.
Re: TMC 2100 and ramps - any pitfalls to avoid? February 23, 2017 08:37PM |
o_lampe
Unfortunately the smart current config pni is also used as "enable". You'd need a tristate driver to switch in that mode ( floating= smart current ).
Also the datasheet mentioned we had to "wake up" the driver after a longer period of idle. Doesn't sound too promising for me....
My TMCs had a weightlifting session today. My CoreXY bed weights ~1.5-2kg and is moved by two ballscrews with 2mm lead. At 24V and Vref at 1.45V they were very quiet and didn't miss a step in 20mins.
Re: TMC 2100 and ramps - any pitfalls to avoid? February 24, 2017 03:04AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 28, 2017 09:34AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 28, 2017 10:05AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 28, 2017 10:15AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 28, 2017 10:26AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 28, 2017 12:07PM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 28, 2017 02:28PM |
Re: TMC 2100 and ramps - any pitfalls to avoid? February 28, 2017 10:06PM |
o_lampe
There's good news and bad news about the white V1.2 TMC's:
Bad news:
The jumper settings are not recognized by the chip. It will run in 16/256 stealthmode, no matter if you do the CF1_to_GND wire hack.
You have to bridge the outermost solderpads on the backside. ( The ones I thought were CF0-5 ).
I found out, because I wanted to configure the Z-stepper in quadstep/256 interpolating mode to reduce z-steps from 1600 to 400/mm. Therefor I also had to bridge the next two pads ( CF2 )
Good news:
The Vref can be reduced a lot afterwards. I've set it to 0.9 instead of 1.5 on my X and Y axis.
You will definitely hear a difference in spreadcylcle mode; the steppers chirp like canaries on extasy.
Re: TMC 2100 and ramps - any pitfalls to avoid? March 04, 2017 07:23AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 04, 2017 07:32AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 04, 2017 09:36AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 04, 2017 09:39AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 04, 2017 09:45AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 04, 2017 10:02AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 05, 2017 02:29PM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 05, 2017 05:09PM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 07, 2017 05:37AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 07, 2017 09:03AM |
o_lampe
RADDS unleashed!
After finding the reason for the vibrating steppers, I replaced the RAPS128 drivers on X & Y axis of my CoreXY with the CF1-modded TMC's
Not only can I print small circles much faster, but I could also crank up the acceleration from 500 to 2000mm/s²!
The printer almost jumps from the table now
And it is still silent in spreadcycle mode.
Replacing drivers: save ~10$ each ( TMC2100 vs RAPS128 )
Fat grin on my face: priceless
Re: TMC 2100 and ramps - any pitfalls to avoid? March 07, 2017 11:45AM |
Re: TMC 2100 and ramps - any pitfalls to avoid? March 08, 2017 10:13AM |
