Re: Re-Arm, any experiences? March 27, 2017 05:31PM |
Re: Re-Arm, any experiences? March 27, 2017 10:21PM |
DjDemonD
Its hard not to conclude here (even though my re-arm is working and print quality is good) that given some of the struggles people seem to be having:
1) if you are on a tight budget go with decent Ramps/Mega and possibly Repetier firmware for improved performance over marlin, Using some of the newer stepper driver chips and potentially 0.9 deg motors will improve your print quality.
2) If you are not on a tight budget get a Duet board, where none of these issues are present, print quality is amazing and the support and community involvement is second to none, right now users get to vote on new features being added to the firmware.
Re: Re-Arm, any experiences? March 28, 2017 02:26AM |
Re: Re-Arm, any experiences? March 28, 2017 02:45AM |
Re: Re-Arm, any experiences? March 28, 2017 02:59AM |
drmaestro
I'll do that, however wire transfer is generally expensive (the last time I checked, it required around 30 USD as a transfer fee).
Re: Re-Arm, any experiences? March 28, 2017 03:58AM |
nebbian
As I suspected:
[attachment 92424 IMG_6676.jpg]
Didn't take long to unsolder, hit the traces with a dremel, and solder some new jumper pins in.
[attachment 92425 IMG_6677.jpg]
It's definitely a trap for young players though. And just... annoying.
Re: Re-Arm, any experiences? March 29, 2017 02:48AM |
Re: Re-Arm, any experiences? March 29, 2017 12:41PM |
Re: Re-Arm, any experiences? March 29, 2017 05:36PM |
sungod3k
Just read the panel section in smoothie documentation and voila the lines disappear as soon as you take out the displays sd card. Also the menu feels more responsive now. I also had some weird crashes/skipped steps during SD prints, so onboard SD card from it is from now on.
Re: Re-Arm, any experiences? March 29, 2017 09:35PM |
Re: Re-Arm, any experiences? March 30, 2017 05:48PM |
Re: Re-Arm, any experiences? March 31, 2017 02:05AM |
Re: Re-Arm, any experiences? March 31, 2017 03:44AM |
Re: Re-Arm, any experiences? March 31, 2017 04:03AM |
panel.button_pause_pin 1.22!^ # kill/pause set one of these for the auxilliary button on viki2
Re: Re-Arm, any experiences? March 31, 2017 04:39AM |
Re: Re-Arm, any experiences? March 31, 2017 08:19AM |
Re: Re-Arm, any experiences? March 31, 2017 09:24AM |
Re: Re-Arm, any experiences? April 08, 2017 10:29AM |
DjDemonD
Pause would be handy keep us posted.
switch.pause.enable true # Enable this module switch.pause.input_pin 1.22!^ # Pin where pause button is connected switch.pause.output_on_command suspend # Suspend command switch.pause.output_off_command resume # Resume command switch.pause.input_pin_behavior toggle # This pin toggles between it's on and off states each time it is pressed and released
Re: Re-Arm, any experiences? April 08, 2017 10:33AM |
Re: Re-Arm, any experiences? April 08, 2017 10:45AM |
Re: Re-Arm, any experiences? April 08, 2017 11:22AM |
Re: Re-Arm, any experiences? April 08, 2017 11:37PM |
Re: Re-Arm, any experiences? April 08, 2017 11:54PM |
Re: Re-Arm, any experiences? April 09, 2017 03:28PM |
Re: Re-Arm, any experiences? April 09, 2017 09:23PM |
Re: Re-Arm, any experiences? April 10, 2017 04:52AM |
Re: Re-Arm, any experiences? April 10, 2017 07:36AM |
Re: Re-Arm, any experiences? April 10, 2017 07:50AM |
Re: Re-Arm, any experiences? April 10, 2017 09:20AM |
Re: Re-Arm, any experiences? April 10, 2017 09:30AM |
