Nozzle size vs speed February 06, 2017 12:17PM |
Re: Nozzle size vs speed February 06, 2017 12:20PM |
Re: Nozzle size vs speed February 06, 2017 12:24PM |
Re: Nozzle size vs speed February 06, 2017 12:49PM |
Re: Nozzle size vs speed February 06, 2017 01:04PM |
Re: Nozzle size vs speed February 06, 2017 01:21PM |
Re: Nozzle size vs speed February 06, 2017 06:15PM |
Re: Nozzle size vs speed February 07, 2017 03:37AM |
Re: Nozzle size vs speed February 07, 2017 04:13AM |
PDBeal
You might have to crank the temperature up 10-15 degrees when you try and print faster as the plastic will spend less time in the heater block section.
Re: Nozzle size vs speed February 07, 2017 11:29AM |
o_lampe
PDBeal
The volcano should have the thermistor closer to the nozzle instead of close to the heater element. It's this hysteresis, why you crank up the temp for compensation.
IMHO the best position would be on the bottom left corner, away from the heater element.
Re: Nozzle size vs speed February 07, 2017 12:11PM |
