Extruder force/gear ratio choices February 22, 2017 12:22PM |
Re: Extruder force/gear ratio choices February 22, 2017 12:25PM |
Re: Extruder force/gear ratio choices February 22, 2017 12:32PM |
Re: Extruder force/gear ratio choices February 22, 2017 01:19PM |
Re: Extruder force/gear ratio choices February 22, 2017 03:13PM |
Re: Extruder force/gear ratio choices February 22, 2017 08:03PM |
Re: Extruder force/gear ratio choices February 22, 2017 08:08PM |
Re: Extruder force/gear ratio choices February 22, 2017 08:12PM |
Re: Extruder force/gear ratio choices February 23, 2017 04:07AM |
Re: Extruder force/gear ratio choices February 23, 2017 05:46AM |
Re: Extruder force/gear ratio choices February 23, 2017 10:15AM |
nebbian
Their 3:1 gear ratio is perfect, the gears are a lot lighter and thinner than a planetary gearbox, and it's an extremely well designed piece of kit. The filament path through the extruder is very well thought out. You pull the lever and push the filament through. It just goes straight through, no poking around at all. I haven't tried a long print with flexibles, but I think it should work really well.
Re: Extruder force/gear ratio choices February 23, 2017 03:25PM |
DjDemonD
The other argument is about retraction speed. Here I disagree with the received wisdom that retraction has to be fast to work. It doesn't. My flex3drive (40:1) can only retract as I currently have it setup at 11mm/s, but I don't get blobs or strings. However if I start turning the speeds up, then the proportion of the time spent retracting and unretracting is longer. So fast retractions (using low or no gearing) are important with faster print speeds so you can keep the speed up but not so you can actually retract the filament. Of course I'm only retracting it 2mm so at 11mm/s it still only takes around 0.4sec to retract/unretract.
Re: Extruder force/gear ratio choices February 23, 2017 04:01PM |
Re: Extruder force/gear ratio choices February 23, 2017 05:24PM |
dc42
it's critical to use a high retraction speed if you use a Bowden extruder that needs a lot of retraction.This is because you need to relieve the pressure in the nozzle quickly to avoid continued extrusion after the end of the extruding move.
