e3d Titan extruder retraction/print speeds
February 24, 2017 07:45AM
Hello!
Recently upgraded to a e3D Titan extruder. It's an impressive little fellow but I'm having some trouble printing off successful 3D Benchies. I was wondering if anyone knows of any good Slic3r profiles settings for the extruder/retraction/speed that I could take a look at?
Re: e3d Titan extruder retraction/print speeds
February 24, 2017 09:10AM
Which filament are you focussing on?
February 24, 2017 05:50PM
I get succesful retracts @ 40mm/s with 1mm retract. Acceleration is set to 350 (i think, I'll have to double check). I've used this with most filament (abs, PLA, nGen)
Edited 1 time(s). Last edit at 02/24/2017 05:51PM by Origamib.
February 25, 2017 01:57PM
@Origamb: direct extruder or Bowden? I'm asking because anything under 2mm is stringy (let's not talk about PET-G smiling smiley )
February 25, 2017 02:09PM
Direct to an E3D V6.
Bowden will obviously use something drastically different, but if they are using Bowden then they should state the length of their bowden otherwise retraction settings of others mean nothing.
February 26, 2017 02:52PM
Using flying extruder so around 20cm bowden tube,
ABS 1.8mm, 50mm/s 0.3mm z-lift
PLA 2.4mm, 50mm/s, 0.3mm z lift
Can say I've ever seen a string or blob.
Simon Khoury
Published:Inventions
