I'm getting some cruddy slicing from Cura with a simple hollow cylinder shape. The design is a replacement for the top of a broom handle. I've made it with a 1.2 mm thick wall. Since my line width is 0.4mm, I'd expect the slicing to be simple, just three concentric circles per layer. Slic3r does this as expected. But Cura generates a crazy path with a bunch of unnecessary movements to fill the space between the inner and outer walls. It's even worse than it looks in the picture, it's actually filling in some parts of the circle, then moving to the other side, then filling in more, then going back to the other side again, and so on. Settings between slic3r and cura are the same, 0.2mm height, 20% infill, same line width and wall counts, etc.
Slic3r |
Cura (ignore the skirt) |
The result: slic3r on the bottom, cura on the top. The crazy cura tool path (which is worst in the lower centimeter of the print for some reason) causes a sloppy result |
The STL file is here:
www.venzon.org]
Any idea what's going on with Cura? I've fiddled with all kinds of settings, to no avail. Even telling Cura to print hollow results in the same weird tool paths, again mostly below the 1cm layer.
Thanks!
Joe
