dlw
Re: Help with setting up Arduino and Ramps 1.4.
August 01, 2017 07:18PM
You were correct, Dust. Well done.
It compiled and uploaded. Thanks!!!
Onward:
The light on the Ramps board is blinking. Is this correct?
The LCD is not on. I've checked the LCD settings and to my knowledge they are correct.
Getting close to blastoff.
August 01, 2017 09:18PM
you have enabled a glcd, but the images I see of various "Prusa i3 Tronxy" all have standard lcd's not Glcd
Are you sure that's what you have? got a photo of just the lcd ? (front and back)
dlw
August 02, 2017 09:36AM
Sorry about photo.
August 02, 2017 11:28AM
Thats a graphical LCD, make sure you have the u8glib library in the right arduino folder then define glcd in config...h and define reprap discount full graphic smart controller.
Simon Khoury
Published:Inventions
dlw
August 02, 2017 11:41AM
//#define ULTRA_LCD // Character based
#define DOGLCD // Full graphics display
// RepRapDiscount FULL GRAPHIC Smart Controller
// [reprap.org]
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
U8glib is in Library.
August 02, 2017 03:13PM
Looks great, is it working?
Simon Khoury
dlw
August 02, 2017 03:50PM
No.
Blink works.
Configuration.h appears to install. Ramps light blinks rapidly. Arduino list 'Done uploading.'
The LCD is blank. Ramps light is off and Arduino's light is on but not the one that blinks every second.
August 02, 2017 06:16PM
There are some LCD's that the cable plugs are around the wrong way, so your forced to plug it in backwards.
This is normally only an issue if you purchased the lcd adaptor separately from the LCD
Its not just a contrast issue is it? (the variable resistor on the left)
dlw
August 03, 2017 07:55PM
Success. The LCD is working.
Problem was, the pins on the LCD adapter did not line up with the Ramps board.
Solved by bending pens.
Current:
X and Y motors do not work. They do not move when tested.
The Z axis sounds horrible. Does work.
When first purchased, I was unable to set it up for some time.
After fighting with it, realized the main board was not good. Seller said 30 days were up.
Replaced with Ramps 1.4 and Arduino.
Next, discovered the power supply put out only 9.3VDC.
Replaced with XT650W.
The motors for the X and Z motors were replaced with Printrbot motors.
The upper cable is from the Printrbot.
The wiring coloring is different. Is that a problem?
I've plugged motor cables into Ramps board both ways.
Any help appreciated.
Edited 1 time(s). Last edit at 08/03/2017 07:59PM by dlw.
