Delta Radius = August 01, 2017 03:35AM |
Re: Delta Radius = August 01, 2017 04:34AM |
Re: Delta Radius = August 01, 2017 06:16AM |
Re: Delta Radius = August 01, 2017 06:23AM |
Re: Delta Radius = August 01, 2017 05:00PM |
Re: Delta Radius = August 01, 2017 05:10PM |
Re: Delta Radius = August 01, 2017 07:19PM |
Dr Bob
Hi
In my Marlin settings for my Delta printer, I have:
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET)
Can I turn this in to an actual number, is it just a case of adding together the measurements of the, DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET so it would look like:
Re: Delta Radius = August 01, 2017 07:21PM |
Re: Delta Radius = August 02, 2017 07:19AM |
DjDemonD
Seriously consider using something like dc42s wizard at escher3d you just have to measure nozzle to bed heights at 6-10 positions on the bed, stick the numbers in along with your starting parameters and it works it all out for you. Unless you plan to use a probe and firmware that calibrates automatically. Seriously consider this it saves you a lot of time.
Re: Delta Radius = August 02, 2017 07:25AM |
Re: Delta Radius = August 02, 2017 07:26AM |
frankvdh
Bob, the calculation is subtraction, not addition:
Re: Delta Radius = August 02, 2017 07:29AM |
Re: Delta Radius = August 02, 2017 05:27PM |
Re: Delta Radius = August 03, 2017 02:01AM |
