Not sure where else to have posted this question:
I copied the info from the terminal window of Octopi. Here is what is happening. From login to print. I've edited out all the temp replies to condense. I've tried running directly off SD card. This is a Dbot corexy printer running Marlin. I can print fine if I slice via cura etc. Tried reinstalling S3D, just downgrading etc, still locks up. When it does, the bed and nozzle stay active at their set temps. Hoping someone can look at this log and tell me what is going on.
Connecting to: /dev/ttyACM0 Connecting to: /dev/ttyACM0 Changing monitoring state from 'Detecting serial port' to 'Opening serial port' Connected to: Serial(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Starting baud rate detection Changing monitoring state from 'Opening serial port' to 'Detecting baudrate' Trying baudrate: 250000 Send: N0 M110 N0125 Recv: \x1e\x06~\x06��\x06~��f��\x06�����\x1ef��\x06�����\x00��\x18�\x06\x18�\x00��\x18���\x06\x18\x06��f��\x06����\x18\x18�\x06��\x06~\x00�f\x06\x06x\x06\x06~f\x06x�\x18\x18x\x00��\x18\x1e��\x06\x18x��\x00\x18\x1e\x00��\x18x�\x18\x18\x18\x18\x06�\x00f~\x06���\x18�~\x00������������\x00\x18����f���f���\x1e����\x00f���f\x06x�\x18\x18�f~��\x00\x18x\x00\x18\x18x\x00���\x1e��f��\x06����\x18\x18\x18fxf\x06�\x1efx����\x18f�~\x00�x\x18\x1ef\x18\x18\x18f�\x06����f����f~x�xf����f\x06~f���~\x00����\x18\x1e�\x18\x06f��\x06����\x18�\x06��\x06x\x1e��fx\x06\x18f�x\x06f~��\x06��fx\x06~����~��\x06\x18���\x06\x06xf\x06x��f��\x06������\x06~f\x06��\x06\x18fx\x18\x06�������~��f��\x06����\x18\x18�\x1ef\x18x\x00\x18f�\x18\x1e\x00\x18�\x00\x18\x18�xf\x18\x1e\x00\x18�\x00\x18\x18\x18�\x06\x18\x18\x18�\x00\x18\x18�\x06f��\x18x��\x00\x18\x18\x06f��\x06�����\x1ef\x06f���ff�\x00\x18xffx��f\x06~f��\x06\x18�������\x1ef��\x18\x06f��\x06����\x18\x18�\x1e�x\x00�x\x00\x18fx\x00\x18\x18�\x00\x18\x18�x�x\x00\x18\x18�\x00\x18\x18\x18�f\x1e��\x00\x18\x18�\x06�\x1ef\x18�\x00\x18\x18\x06f��\x06�����\x1ef\x06f���ff�\x00�\x00����fx��f��f\x06~������\x00\x18�������\x1e�x���\x18\x06f��\x06����\x18\x18�\x1e�x\x00��\x18\x18fx\x00\x18\x18\x18�x�x\x00\x18\x18\x18\x18�f\x18\x18\x18�\x06�\x06\x18\x18\x18\x18\x18\x06f��\x06�����\x00����fx��f��f\x06~������\x1e�~\x00\x18f�\x18��f���f���~\x06�\x00\x18�f\x18�fx��f��\x06~\x00����\x06\x18f�\x18~\x18f�~f\x06���f��\x06����\x18\x18�\x1e�x\x00\x18\x1e\x00\x18�\x1e\x18\x18\x18\x18�\x00\x18\x18\x18��\x1e\x18\x18\x18\x18�\x00\x18\x18\x18f\x1e\x18\x18\x18\x18�\x00\x18\x18\x06f��\x06�����\x00\x06xxf��\x1efx\x06\x18~\x06��f�\x06��\x06�f���~\x00��f�\x1ef���\x00\x18xffx��f\x06~f\x06\x18�������\x1ef���\x00\x18f��\x1ef���\x00\x18~\x18f�~f\x06�\x00\x18xffx��f\x06~f\x06\x18�������\x1ef���\x00\x18�f��f�������ff�\x00��fx~f�f��\x06\x18~����f\x06\x18���\x1ef���\x00\x18f���f\x06f���ff�\x00\x18fx\x06\x18�fx\x18��\x06\x18�������\x1ef���\x00\x18\x18�f��f\x06f���ff�\x00\x18�\x06\x18�fx\x18��\x06\x18�������\x1ef���\x00\x18�\x06f��f\x06f���ff�\x00�\x06\x06\x18�fx\x18��\x06\x18�������\x1ef���f��\x06����\x18\x18�\x1e�x\x00��\x18��\x06\x18�\x00\x18\x18\x18f\x00\x18�\x00\x18\x18\x18��\x18\x18\x18\x18\x18\x18\x18fx\x00\x18�\x00\x18\x18�xf��\x18�\x00\x18\x18\x18�\x06\x18�\x18\x18�\x06f\x1e��\x00\x18\x18\x06f��\x06����\x18�����f\x06��x�x\x1efx\x06\x18���������f��\x06����\x18\x18�\x1e�x\x00\x18\x1e\x00\x18f\x18�\x00\x18\x18�x\x06\x18�\x00\x18\x18\x18�\x06\x18�\x00\x18\x18\x06f��\x06�����\x1ef\x06~f��f�\x06\x06�\x00\x18�ff\x06~f\x06\x06\x18f��ff�f\x06~f�����~��f��\x06����\x18\x18�\x1ef\x18\x1ef\x18��\x06\x18\x18�\x06\x18\x18\x18\x18��\x1e\x00\x18\x18\x00\x18\x06\x00\x18�\x1ef\x18\x1ef\x18��f\x18\x18�\x18\x18\x1e\x00\x18\x18�f\x18\x18\x18\x00\x18\x06f��\x06����\x18f\x18\x06\x00��fx\x06~����~���~��f��\x06����\x18\x18�\x1e�x\x00��\x18\x18f�\x18\x1e��~\x18\x18�\x18f\x18�\x18\x18\x1e\x00\x18`�x��\x18��\x18\x06f��\x06����\x18\x18�\x1e�x\x00\x18\x1e\x00\x18fx\x1e\x18\x18�f\x18\x18�\x18�x�\x18�\x00\x18\x18\x18\x1e�x�\x18��\x18\x18\x06f��\x06����\x18����\x06f�f��\x06��fx\x06~����~���~\x00\x18��\x1ef��\x06�f\x06x��f��\x06����\x18\x18�\x1e�x\x00\x18\x18\x18\x1e\x18�\x00\x18\x18\x06f��\x06����\x18\x18�\x1e�x\x00\x18\x18\x18\x00\x18\x06f��\x06����\x18�f�\x00f���\x18fx\x00��x�x\x1efx\x06\x18��������\x18\x06f��\x06����\x18\x18�\x1e\x06����\x18\x18�f�\x06\x18�\x00\x18\x18\x06f��\x06������\x06\x00��f��\x06x\x00������ Baudrate test retry: 4 Send: N0 M110 N0125 Baudrate test retry: 3 Send: N0 M110 N0125 Baudrate test retry: 2 Send: N0 M110 N0125 Baudrate test retry: 1 Send: N0 M110 N0125 Baudrate test retry: 0 Send: N0 M110 N0125 Trying baudrate: 230400 Send: N0 M110 N0125 Baudrate test retry: 4 Send: N0 M110 N0125 Baudrate test retry: 3 Send: N0 M110 N0125 Baudrate test retry: 2 Send: N0 M110 N0125 Baudrate test retry: 1 Send: N0 M110 N0125 Baudrate test retry: 0 Send: N0 M110 N0125 Trying baudrate: 115200 Send: N0 M110 N0125 Recv: echo:Unknown command: "���M�%�XA����M�%�XA����M�%�Xa����M�%�X!����M�%�Xa����D��������DB��S2��D��������DC��+.��DB��S���" Recv: ok Changing monitoring state from 'Detecting baudrate' to 'Operational' Send: N1 M10538 Recv: ok Send: N0 M110 N0125 Recv: ok T:170.0 /0.0 B:72.3 /0.0 @:0 B@:0 Send: N1 M11539 Recv: ok Send: N2 M2118 Recv: FIRMWARE_NAME:Marlin 1.1.0-RC8 (Github) SOURCE_CODE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPEgrinning smileyBOT EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff Recv: ok Recv: echoconfused smileyD card ok Send: M20 Recv: ok Recv: Begin file list Recv: End file list Recv: ok Send: M105 Recv: ok T:152.0 /0.0 B:69.1 /0.0 @:0 B@:0 Changing monitoring state from 'Operational' to 'Printing' Send: N0 M110 N0125 Recv: ok Send: N1 G9017 Recv: ok Send: N2 M8227 Recv: ok Send: N3 M106 S255102 Recv: ok Send: N4 G4 P500108 Recv: ok Send: N5 M106 S098 Recv: ok Send: N6 M140 S9090 Recv: ok Send: N7 M190 S9086 Recv: T:91.7 /0.0 B:90.0 /90.0 @:0 B@:53 W:0 Recv: ok Send: N8 M104 S235 T045 Recv: ok Send: N9 M109 S235 T033 Recv: T:91.6 /235.0 B:90.0 /90.0 @:127 B@:58 Wmoody smiley Recv: T:235.0 /235.0 B:90.0 /90.0 @:44 B@:58 W:0 Recv: ok Send: N10 G2834 Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: X:152.00 Y:192.00 Z:2.00 E:0.00 Count A: 55040 B:-6400 Z:1600 Recv: ok Send: N11 G2934 Recv: G29 Auto Bed Leveling Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: Bilinear Leveling Grid: Recv: 0 1 2 3 Recv: 0 -0.64 -0.41 -0.17 -0.10 Recv: 1 -0.42 -0.28 -0.09 -0.03 Recv: 2 -0.32 -0.06 +0.17 +0.17 Recv: 3 -0.17 +0.21 +0.38 +0.30 Recv: Recv: X:289.00 Y:299.00 Z:1.70 E:0.00 Count A: 94080 B:-1600 Z:1600 Recv: ok Send: N12 G92 E0116 Recv: X:289.00 Y:299.00 Z:1.70 E:0.00 Count A: 94080 B:-1600 Z:1600 Recv: ok Send: N13 G1 E-6.5000 F540040 Recv: ok Send: N14 G1 Z0.600 F100242 Recv: Error:Line Number is not Last Line Number+1, Last Line: -1059816696 Recv: Resend: -1059816695 Printer requested line 1059816695 but no sufficient history is available, can't resend Changing monitoring state from 'Printing' to 'Error: Printer requested line 1059816695 but no sufficient history is available, can't resend' Recv: ok Recv: ok Recv: echo:Unknown command: "�I\x01\x0e" Recv: ok Recv: echo:Unknown command: "��" Recv: ok
Edited 1 time(s). Last edit at 08/02/2017 05:02PM by Dbotrunner.
Re: Simplify3D 4 keeps bombing out my prints after autobed routine and begin of first layer.
August 02, 2017 06:46AM
Commercial software with their own support system...
Please see [forum.simplify3d.com]
Yeah unfortunately they won't be able to help me. Hoping someone here has run into this issue before.
It appears that you are connecting at 115200 "in Red"
baudrate=115200,
bytesize=8,
xonxoff=False,
rtscts=False,
dsrdtr=False),
starting monitor
Then here you are disconnected.
Seeing how you were connected, then lost connection. I would suggest a better USB Cable.
The remaining data appears to be testing different baud rates to try and re-establish the connection.
Even though you had a connection this does not rule out the possibility that setting for a connection were 100% correct.
As timeout settings are set for 10 seconds.
Edited 1 time(s). Last edit at 08/02/2017 05:58PM by Roberts_Clif.
So things I've tried. Two different short length blue USB cables ( the ones you get with a ramps board ) and two USB cables with ferrite beads on both ends.
Removing the raspi out of the equation entirely and running the file from the LCD graphics controller yields the same results.
Did you change the baud rate to 250000?
The baud of my machine in ramps is 125000. I've set the setting in Simplify3D to the same baud.
Also wanted to add, if I slice a file via slic3r, the printer prints fine. Just Simplify3D gcode is doing this.
