I got a Buck Converter, Now What? August 05, 2017 07:01PM |
Re: I got a Buck Converter, Now What? August 05, 2017 07:13PM |
Re: I got a Buck Converter, Now What? August 05, 2017 07:40PM |
Re: I got a Buck Converter, Now What? August 06, 2017 12:16AM |
Re: I got a Buck Converter, Now What? August 06, 2017 12:18AM |
Re: I got a Buck Converter, Now What? August 06, 2017 01:43AM |
Re: I got a Buck Converter, Now What? August 06, 2017 05:43PM |
Re: I got a Buck Converter, Now What? August 06, 2017 06:12PM |
Re: I got a Buck Converter, Now What? August 06, 2017 07:35PM |
Re: I got a Buck Converter, Now What? August 06, 2017 07:55PM |
Re: I got a Buck Converter, Now What? August 06, 2017 08:26PM |
Re: I got a Buck Converter, Now What? August 06, 2017 08:35PM |
Re: I got a Buck Converter, Now What? August 06, 2017 08:47PM |
Re: I got a Buck Converter, Now What? August 06, 2017 09:40PM |
Re: I got a Buck Converter, Now What? August 06, 2017 11:38PM |
Re: I got a Buck Converter, Now What? August 07, 2017 02:05AM |
DD
A boost converter that can power an underspecced bed heater would cost more than just buying a new power supply. That would be a silly use for a boost converter.
You can connect two 12V fans in series and run them from 24V. There's no guarantee they'll split the voltage evenly, but it will be close enough. A few volts either way won't matter much.
Re: I got a Buck Converter, Now What? August 07, 2017 02:31AM |
Re: I got a Buck Converter, Now What? August 07, 2017 06:49AM |
Re: I got a Buck Converter, Now What? August 07, 2017 11:20AM |
Re: I got a Buck Converter, Now What? August 07, 2017 11:36AM |
MechaBits
It's kinda free everywhere else but Earth, and especially when OPEC are involved.
Re: I got a Buck Converter, Now What? August 07, 2017 11:41AM |
Re: I got a Buck Converter, Now What? August 11, 2017 03:10AM |
the_digital_dentist
... With those buck converters (and many other types of DC-DC converters) you have to be careful- many are designed so that the input and output have to be isolated and will not work right or may be damaged or destroyed if you connect the input to the output. For example, unless the data sheet says it is safe to do so, don't connect the converter's negative input terminal to the negative output terminal. Some converters have a single ground pin that is used for both input and output. ...
Re: I got a Buck Converter, Now What? August 11, 2017 07:13AM |
Re: I got a Buck Converter, Now What? August 11, 2017 09:42AM |
Re: I got a Buck Converter, Now What? August 11, 2017 10:04AM |
Re: I got a Buck Converter, Now What? August 19, 2017 08:25AM |
