3D printer emit toxic fumes survey August 24, 2017 01:13PM |
Re: 3D printer emit toxic fumes survey August 24, 2017 03:55PM |
Re: 3D printer emit toxic fumes survey August 25, 2017 12:41AM |
Re: 3D printer emit toxic fumes survey August 25, 2017 03:56AM |
Re: 3D printer emit toxic fumes survey August 25, 2017 05:58AM |
Re: 3D printer emit toxic fumes survey August 25, 2017 06:00PM |
Re: 3D printer emit toxic fumes survey August 25, 2017 06:06PM |
Re: 3D printer emit toxic fumes survey August 27, 2017 01:23AM |
Re: 3D printer emit toxic fumes survey August 28, 2017 01:19PM |
Re: 3D printer emit toxic fumes survey August 29, 2017 03:55AM |
Re: 3D printer emit toxic fumes survey August 29, 2017 12:41PM |
briangilbert
Here's what I did..
[www.youtube.com] (have since run the exhaust hose out the window)..
Re: 3D printer emit toxic fumes survey August 29, 2017 02:38PM |
Re: 3D printer emit toxic fumes survey August 29, 2017 03:01PM |
ohfurryone
If you're going to say that all materials release dangerous fumes, you should also suggest users throw away a vast majority of their plastics as their off-gassing is far worse than days worth of printing with clean filament.
Re: 3D printer emit toxic fumes survey August 30, 2017 07:29AM |
Re: 3D printer emit toxic fumes survey August 31, 2017 12:26AM |
Re: 3D printer emit toxic fumes survey September 03, 2017 03:37PM |
Re: 3D printer emit toxic fumes survey September 03, 2017 08:21PM |
Re: 3D printer emit toxic fumes survey September 03, 2017 10:58PM |
Re: 3D printer emit toxic fumes survey September 04, 2017 07:18AM |
Re: 3D printer emit toxic fumes survey September 04, 2017 08:21AM |
Re: 3D printer emit toxic fumes survey September 04, 2017 09:13AM |
Re: 3D printer emit toxic fumes survey September 04, 2017 09:35AM |
Re: 3D printer emit toxic fumes survey September 04, 2017 09:50AM |
newbob
Industrial guidelines show the need for ventilation and that styrene concentrations above 100ppm require use of respirator.
Re: 3D printer emit toxic fumes survey September 04, 2017 09:57AM |
WesBrooks
This in my office would be 2.2mg / 24.7m3 = 0.089mgm-3
According to the first reference the times mgm-3 values by around 0.235 to convert to ppm.
0.089 * 0.235 = 0.021ppm
There would appear to be quite a significant safety margin between the levels emitted and a risk to health?
I have no argument against handling the emissions, but accidentally eating apple pips would appear more dangerous at the moment! There are notes to this though, as I mentioned before. As there is a point source of of emission and the emitted gasses/particulates disperse then there will be areas of the room with higher contamination levels, such as in the immediate vicinity of the machine. It is also worth noting that people tend to be very sensitive to some chemicals and it is likely that you will choose to do something about the fumes long before it becomes a critical safety concern.
Re: 3D printer emit toxic fumes survey September 04, 2017 10:03AM |
Re: 3D printer emit toxic fumes survey September 04, 2017 10:08AM |
