CoreXYU -> CoreXYE August 30, 2017 08:41AM |
Re: CoreXYU -> CoreXYE August 30, 2017 09:01AM |
Re: CoreXYU -> CoreXYE August 30, 2017 01:01PM |
Re: CoreXYU -> CoreXYE August 30, 2017 01:21PM |
Re: CoreXYU -> CoreXYE August 30, 2017 02:09PM |
Re: CoreXYU -> CoreXYE August 30, 2017 02:58PM |
Re: CoreXYU -> CoreXYE August 30, 2017 04:40PM |
Re: CoreXYU -> CoreXYE August 30, 2017 08:56PM |
dc42
Avoid MXL pulleys and belts unless you are willing to pay for pricey Western-manufactured pulleys. The Chinese so-called MXL pulleys I have come across have the wrong tooth profile. The MXL belt has wider gaps between teeth than the width of each tooth, therefore the teeth on the pulleys needs to be wider than the gaps, otherwise you get horrendous backlash.
Re: CoreXYU -> CoreXYE August 31, 2017 01:34AM |
Re: CoreXYU -> CoreXYE August 31, 2017 07:22AM |
Re: CoreXYU -> CoreXYE August 31, 2017 08:05AM |
Re: CoreXYU -> CoreXYE September 01, 2017 01:37AM |
o_lampe
Another problem not addressed yet is the orientation of the drive gear. The drive gear shaft is horizontal, while idlers and pulleys are vertical.
Re: CoreXYU -> CoreXYE September 01, 2017 10:10AM |
Re: CoreXYU -> CoreXYE September 02, 2017 07:29PM |
Re: CoreXYU -> CoreXYE September 04, 2017 10:50AM |
