Heatbed Mosftet to hot
September 18, 2017 09:57AM
hi
last night i tested my heatbed with ramps 1.4, from my powersupply i seen that heatbed was drawning 5 Amps at 12v, after afew minutes i start smelling burning and shut all up and i toutch the mosfet of ramps and was like burning
from what i see the ramps 1.4 have STB55NF06 mosfets ratings of 50 A so i would tought this would be ok to hold the 5 Amps, my guess is it shouldnt get that hot
what could be the problem?
should i replace the mosfet with the Mosfet IRF1404 that can hold up to 202 A ?
if so should i replace also the mosfet from extruder with the IRF1404?
another option could be use a relay but if the IRF404 could not get that hot then would be better option replace the Mosfet
i tought the ramps.14 design would be better prepare for 12v heatbeds system
the heatbed i have is a Reprap Standard 3D Printer 3mm MK3
Edited 1 time(s). Last edit at 09/18/2017 09:59AM by Meph.
Re: Heatbed Mosftet to hot
September 18, 2017 04:46PM
The MOSFETs on RAMPS were poorly chosen (as on some other 8-bit 3D printer control boards) but despite the number of revisions that RAMPS has been through, the part number has never been updated.
Suitable replacements include IRLB8743 and IRLB3034.
Edited 2 time(s). Last edit at 09/18/2017 04:50PM by dc42.
September 18, 2017 05:52PM
official ramps also has a heatsink around the heated bed mosfet... which no supplier provides!
but it is best to replace the mosfet with something better
September 19, 2017 08:38AM
i have found some IRF1404 Mosfets on my local store maybe i shuld replace all 3 mosfets with it
Edited 1 time(s). Last edit at 09/19/2017 08:50PM by Meph.
September 19, 2017 07:26PM
You could replace the mosfet, heatsink them, use an external mosfet for the bed, or a relay or just stick a fan over the top of them. The world's your oyster.
Simon Khoury
Published:Inventions
September 20, 2017 07:12AM
IRF1404 is not a good choice because it needs a higher gate voltage than Arduino/RAMPS provides.
September 20, 2017 12:34PM
IRF1404 VGS is less then 5v
i havse seen ramps 1.4 selling with IRF 1404
EX [elektronicke-stavebnice.heureka.cz]
Edited 1 time(s). Last edit at 09/20/2017 12:48PM by Meph.
September 20, 2017 04:07PM
Meph
It was designed by an amateur then.
September 21, 2017 11:38AM
I have order the irlb3034 mosfets
one more question, im powering the ramps 1.4 with 12v and when i turn on bed i measure 9.5 volts on the outputs of D8 is that normal?
September 21, 2017 03:00PM
Meph
There will be voltage drop in the power cables between the PSU and RAMPS, in the 11A polyfuse, and in the mosfet. Replacing the mosfet by a better one will reduce its voltage drop.
