Anti-ooze valve for extruder October 17, 2017 12:46AM |
Re: Anti-ooze valve for extruder October 17, 2017 04:10AM |
Re: Anti-ooze valve for extruder October 17, 2017 09:44AM |
Re: Anti-ooze valve for extruder October 17, 2017 11:35AM |
leadinglights
One thought though, using the identical arrangement but with the pin fixed so that the 'O' ring and gap don't exist, but having the nozzle sprung and floating so that when the filament is retracted the nozzle also retracts and seats against the pin. The above problems of the 'O' Ring and gunge-blockage still exist but the mechanicals would have been simplified.
Mike
Re: Anti-ooze valve for extruder October 17, 2017 11:42AM |
obelisk79
I wonder how that zig-zag path you've got the material passing throuh will affect pressure and neccesary torque to push the filament through. Of course the concept could work quite well if you decide to create a prototype.
Re: Anti-ooze valve for extruder October 17, 2017 01:17PM |
Re: Anti-ooze valve for extruder October 17, 2017 02:27PM |
Re: Anti-ooze valve for extruder October 17, 2017 02:33PM |
o_lampe
Wouldn't the pin push filament through the nozzle each time it closes the channel? What would be the chamber pressure after unretract? There could be a gap in the filament.
If you would guide the pin sideways into the nozzle, you could again use a straight melting path.
Re: Anti-ooze valve for extruder October 17, 2017 02:37PM |
o_lampe
Re: Anti-ooze valve for extruder October 17, 2017 02:45PM |
LoboCNC
I'm not too worried about the zig-zag path. My current printer (UDIO printer) uses a right-angle extruder which has given me no problems at all in the year or so I've been using it. Normally I'd be worried about the relatively large volume of melted material inside the heater block because this causes more oozing, but with the valve, it shouldn't matter.
Re: Anti-ooze valve for extruder October 17, 2017 03:05PM |
obelisk79
Since that thing prints upside down, do you even notice much of an ooze problem?
Re: Anti-ooze valve for extruder October 18, 2017 09:22AM |
LoboCNC
Actually, it turns out that ooze, and pretty much all other 3D printing factors, have little to do with gravity. The viscodynamic and thermal forces are far greater than the weight of the filament. Printing upside down, even bridging, looks pretty much the same as printing right-side up. Oozing, in particular doesn't care about gravity. The biggest factor I've found is the volume of melted plastic in the heater block. I'm not sure if it is related to thermal expansion of the filament, or maybe some amount of outgassing that happens in the heater block, but larger melted volumes of filament will cause much more oozing than smaller volumes.
Re: Anti-ooze valve for extruder October 18, 2017 12:36PM |
obelisk79
LoboCNC
Thanks for the info. Perhaps thermal expansion is more to blame, wouldn't outgassing potentially cause inconsistent flow from the nozzle?
Re: Anti-ooze valve for extruder October 20, 2017 04:38PM |
Re: Anti-ooze valve for extruder October 20, 2017 04:55PM |
leadinglights
Whether the pin pushes any filament through the nozzle or not would depend on if the filament retract was effective before the pin closed off the nozzle.
In the case of the floating nozzle, since the lifting of the nozzle to meet the pin is done by retracting the filament, I think there would be nothing in the nozzle to be pushed out. Incidentally, the nozzle being lifted would help it to clear the print in the case of multi filament printers.
Regarding obelisk79's concern that the nozzle would wobble, I think it is easy to engineer around that problem - LoboCVC's thought about the diaphragm spring sounds like a very good way of de-wobbling as well as helping with the sealing.
Mike
Re: Anti-ooze valve for extruder October 21, 2017 09:54AM |
Re: Anti-ooze valve for extruder October 21, 2017 03:37PM |
Lykle
afaik, the retraction does not suck the molten filament up into the heat block.
It simply relieves some of the pressure, but there is no negative movement of the molten plastic.
So yeah, closing the needle will have a pulse effect of pushing some filament out.
That can be used, by retracting early and closing the valve slowly, using the pushed out material to finish the track.
That would take a lot of control and precision in the needle valve.
Re: Anti-ooze valve for extruder October 22, 2017 05:26PM |
Re: Anti-ooze valve for extruder February 07, 2018 02:27PM |
Re: Anti-ooze valve for extruder February 07, 2018 02:53PM |
aimdy
hello LoboCNC, i am not sure how far along you are but please check the following patents before investing a lot of money in this project. the design you mention is already in use in a fairly popular machine, the only difference is that the filament in yours feeds parallel to the valve pin. as you guessed the o-ring seal is the weakest point as it generally last only about 500hrs in this harsh environment, sometimes more sometimes less. The issue in the particular head i am referring to is that it fails due to pressure then the filament is allowed to escape through the orifice or at the thread area in that location. I have two of these machine and it is a common issue acknowledged by the manufacturer. Maybe a particularly strong o-ring with high temp resistance will do the trick. Not sure how well ptfe will perform but it could limit what materials you can print with as already observed. You may not be working on this for any financial gain so this message may not be applicable to you, i was not sure. In either case i am sure you can complete the project and your head will print well if implemented correctly, but for retail purposes you may face a road-block unless you are able to design it as such that you do not infringe on any of the patent claims and that would require a pretty good lawyer. I hope this is useful, i design 3D printers and innovative parts too so I would hate for you to get in trouble over patent infringement law.
[www.google.com]
[www.google.com]
Best,
Moh
Re: Anti-ooze valve for extruder February 08, 2018 10:46AM |
When they want to pause printing, or switch nozzles, the current nozzle is plugged completely with a small needle, stopping the flow of filament and producing a perfect ‘end’ to the line or layer of print. This also facilitates the ability of the printer to manage the pause and resume function, another CEL-Robox innovation.
Re: Anti-ooze valve for extruder February 08, 2018 11:33AM |
newbob
There's (was?) printer made in Australia with valve in the nozzle. From what I recall it was causing all sorts of issues.
Found it: https://www.wiltronics.com.au/Robox-3Dprinting/nozzle-valve-system/
From their description though, it looks like needle valve is not used during retractions:
Printing head costs $2500 which could mean that users see some value in such design....LAST EDIT: used, like new CEL-Robox on Amazon goes for $300 so maybe not
Re: Anti-ooze valve for extruder February 08, 2018 12:09PM |
Re: Anti-ooze valve for extruder February 08, 2018 12:28PM |
aimdy
this is the machine i was referring to. you can see here a basic cartoon of what happens in the heater block
[www.cel-robox.com]
this shows the needle valves (pin) as well from outside the heater block in the dual material head
[cel-uk.com]
they offer a single material head, with 2 nozzles for .3mm and .8mm and a dual material head with .4mm nozzles.
The main issue is as I mentioned in my initial post. The machine's proprietary software and slicer provides calibration tools so the machine knows how to precisely calibrate the pin movements. Additional issues may result from the user not properly calibrating their machines. Also as the machine is closed source the manufacturer provide firmware updates, which is one way fine tuning of the pin behavior can be implemented. On a well calibrated machine the user should have no problem other than the longevity of the o-rings.
Re: Anti-ooze valve for extruder February 08, 2018 12:55PM |
Re: Anti-ooze valve for extruder February 08, 2018 01:07PM |
Re: Anti-ooze valve for extruder February 08, 2018 01:36PM |
Re: Anti-ooze valve for extruder February 18, 2018 09:10AM |
LoboCNC
OK, here's another version of the anti-ooze valve that eliminates the complex extruder motor driven actuation and instead uses the differential extrude/retract pressure to operate the valve, as leadinglights suggested. It uses compressed air in a small chamber in the heater block to push the valve pin against the inside of the orifice during retraction, when the inner pressure filament pressure is zero. During extrusion, the high extrusion pressure will push the valve pin upward against the air-spring. A sealed compression screw can be used to compress the air in the air chamber to the proper level. It still has an o-ring seal, which could be problematic, but at least this something I have a hope being able to fabricate.
Re: Anti-ooze valve for extruder February 18, 2018 11:45AM |
newbob
What I find intriguing is the idea of offset chamber where filament is pressing on the wall as it's being fed which may speedup melting due to better heat transfer.
Re: Anti-ooze valve for extruder February 19, 2018 08:29AM |
newbob
LoboCNC
To push the pin up using pressure you'll need melted plastic press on part of the plunger, larger the surface area means bigger gasket and mechanism would be harder to clean/keep aligned once contaminated. I like the original cam idea better. Another negative is changing melt chamber volume when using pressure to produce mechanical energy.
