searching GNU CNC Gcode generator October 22, 2017 01:32PM |
Re: searching GNU CNC Gcode generator October 22, 2017 04:05PM |
Re: searching GNU CNC Gcode generator October 22, 2017 04:46PM |
Re: searching GNU CNC Gcode generator October 22, 2017 07:10PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: searching GNU CNC Gcode generator October 23, 2017 03:30AM |
Re: searching GNU CNC Gcode generator October 23, 2017 04:10PM |
prot0typ1cal
Machining away material [...] will need dedicated firmware.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: searching GNU CNC Gcode generator October 23, 2017 04:47PM |
redblunt
now i am looking for a GNU gcode generator to
Re: searching GNU CNC Gcode generator October 23, 2017 07:02PM |
Re: searching GNU CNC Gcode generator October 24, 2017 02:32AM |
Traumflug
CNC milling specials like cutter compensation are nice and dandy, but useful for manually written programs, only.
I'm thinking more about work offsets, probing (not the z-bed kind), tool tables, etc... CNC without support for toolchange is extremely painful.
Re: searching GNU CNC Gcode generator October 24, 2017 06:21AM |
prot0typ1cal
And silly little things like circular interpolation...
Re: searching GNU CNC Gcode generator October 24, 2017 12:20PM |
Re: searching GNU CNC Gcode generator October 24, 2017 12:48PM |
Traumflug
I thought we were talking about milling here. Machines coming with a tool changer (what a luxury) most likely have a firmware already, no need to replace that one.
Re: searching GNU CNC Gcode generator October 24, 2017 12:56PM |
prot0typ1cal
handy in a production environment
prot0typ1cal
work piece placement is always a variable, even if it can be worked around if you know where the part is relative to machine travel BEFORE programming.
Re: searching GNU CNC Gcode generator October 24, 2017 01:06PM |
Its the kind of stuff you might not notice if you've never seen it before
Re: searching GNU CNC Gcode generator October 24, 2017 01:25PM |
Traumflug
Believe me, I've done this hundreds of times and never needed a tool changer or "responsive" jogging or cutter compensation or length offset or whatever reasons you try to find here for keeping people away from milling.
Re: searching GNU CNC Gcode generator October 24, 2017 01:49PM |
it just doesn't make sense to recommend 3d printer electronics for milling when there are alternatives which are more suitable for the task.
[...] to run a marlin powered CNC with it.
Re: searching GNU CNC Gcode generator October 24, 2017 02:27PM |
Re: searching GNU CNC Gcode generator October 24, 2017 04:41PM |
Traumflug
prot0typ1cal
This is RepRap, so hobbyists, no production environment.
prot0typ1cal
Didn't expect to have to explain such simple things to people talking about production environments.
Work piece placement isn't a variable. X and Y is known from the cutter before, for the first cutter a rather coarse placement is sufficient. Z is simply set (see the hint on G92) after touching the workpiece with the cutter manually. Instead of adjusting tool length one simply moves the coordinate system. Tooltip == Z0 at the touching point is easy to remember, so one generates G-code for that. Has always worked, from ancient non-CNC mills to MAHO with Phillips 232 controller to modern Homags to hobbyist machines like WolfStrap or Mantis.
It's disappointing that such discussions are needed to get feet of owners of $100,000 machines back down to the floor. Such discussions shy people away from tasks they can perfectly do with the tooling they already have or with low budget investments.
Re: searching GNU CNC Gcode generator October 24, 2017 04:43PM |
Re: searching GNU CNC Gcode generator October 24, 2017 06:40PM |
At the hobby level you still toolchange since machining with one cutter isn't a ton of fun. Generally the program will pause and raise the spindle so you can manually swap the tool. If your toolholders repeat in Z you can just look up the new offset and continue; otherwise you can probe the new tool against a height setter and then continue the program.
Re: searching GNU CNC Gcode generator October 24, 2017 07:13PM |
Re: searching GNU CNC Gcode generator July 07, 2020 04:27AM |
Re: searching GNU CNC Gcode generator July 07, 2020 10:24AM |
Admin Registered: 11 years ago Posts: 3,096 |
VDX
... not so "hot" anymore - check the date of the last post
Re: searching GNU CNC Gcode generator July 07, 2020 11:00AM |
