Extruder head
Posted by Anonymous User
Anonymous User
Extruder head
January 05, 2008 11:28AM
Last night I was able to cut the extruder screw drive bearings in seconds. I just placed the bearing into a pair of vice grip pliers setting it so it hold firm but not crush the bearing. Then I held it against a bench grinder for a few seconds and cleaned it up with a small file. It worked so well and so quickly, maybe someone could just make dozens of these at a time and send them to Zach to put in the kits instead of the whole bearings.
Re: Extruder head
January 05, 2008 05:34PM
Yeah, that's the same method I used for my bearings. I had to turn them down on lathe, part them off, and then grind them down to halves. Very easy and quick.
Demented
Re: Extruder head
January 05, 2008 09:16PM
that would be awesome!
what did you use as bearing stock? did you use the small circle bearings/spacers that came in the extruder kit?
Anonymous User
Re: Extruder head
January 06, 2008 05:35AM
Yes. I used the bearings from the kit.
Re: Extruder head
January 07, 2008 08:04AM
Kept telling Zach he needs a grinder in his shop winking smiley I need to shop for one myself.
Cheap!, can you possibly post photos of your technique?
Edited 1 time(s). Last edit at 01/07/2008 08:05AM by RoundSparrow.
Anonymous User
Re: Extruder head
January 09, 2008 12:42PM
We can take some photos to post next time we cut bearings. If you have some that need to be cut, bring them with you and we'll take photos this weekend.
