Things you should buy when starting with a 3D-Printer... January 31, 2018 06:39AM |
There are some 3D printed projects which come with "fume extraction" (simply a fan) for soldering.
E.g. I use 100x2.5 mm.
- ready to recycle when you have built your filament extruder.
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 06:52AM |
Admin Registered: 14 years ago Posts: 7,282 |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 06:56AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 07:31AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 07:49AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 08:18AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 09:11AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 09:53AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 10:09AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 11:42AM |
luke
Further Comments welcome - Things I am not sure about:
set square
spirit level
dial indicator
Didn't use them to much :/
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 11:43AM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 01:05PM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 01:52PM |
Re: Things you should buy when starting with a 3D-Printer... January 31, 2018 02:25PM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 03:34AM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 04:47AM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 04:49AM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 07:22AM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 04:06PM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 05:00PM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 06:08PM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 06:17PM |
Re: Things you should buy when starting with a 3D-Printer... February 01, 2018 09:32PM |
Re: Things you should buy when starting with a 3D-Printer... February 02, 2018 08:55AM |
Re: Things you should buy when starting with a 3D-Printer... February 02, 2018 03:58PM |
Re: Things you should buy when starting with a 3D-Printer... February 02, 2018 04:01PM |
Re: Things you should buy when starting with a 3D-Printer... February 02, 2018 05:17PM |
Re: Things you should buy when starting with a 3D-Printer... February 02, 2018 05:25PM |
DjDemonD
If we're talking safety gear then kevlar gloves come highly recommended. Brand new craft knife cannot cut them. Use when getting parts off the bed or trimming them.
Re: Things you should buy when starting with a 3D-Printer... February 02, 2018 05:36PM |
Re: Things you should buy when starting with a 3D-Printer... February 03, 2018 02:28AM |
DjDemonD
Not for tightening your hotend!
