thoughts on this design February 08, 2018 05:22PM |
Re: thoughts on this design February 08, 2018 06:56PM |
Re: thoughts on this design February 08, 2018 10:36PM |
Re: thoughts on this design February 09, 2018 12:42AM |
Re: thoughts on this design February 09, 2018 07:11AM |
Re: thoughts on this design February 09, 2018 11:00AM |
Re: thoughts on this design February 09, 2018 02:12PM |
MKSA
You are half way to a Ultimaker. Keep going.
Re: thoughts on this design February 09, 2018 02:43PM |
?Quote
Origamib
MKSA
Why? Ultimaker has weight limitations that a standard axis does not. It also relies on the use of rods and bearings and the slop associated unless you buy quality
Standard cartesian designs have the advantage of easily adding extra tools, direct drive or even multiple X gantries
Re: thoughts on this design February 09, 2018 07:41PM |
Re: thoughts on this design February 10, 2018 11:05AM |
Re: thoughts on this design February 10, 2018 02:57PM |
the_digital_dentist
The Cubex machines have a very heavy extruder carriage and a cantilevered bed. The extruders are crappy, but it you replace them with decent extruders, and put in a controller board that doesn't need proprietary filament cartridges, they can print well as long as you keep the print speed down to 30-40 mm/sec. Faster than that and the bed tends to bounce a lot. The XY stuff is OK (not great- I'm not fan of dual motors for anything), but I would not recommend a cantilevered bed for any but very small machines. 3 screws driven by 1 motor with two linear guides should provide a stable bed. A belt lifted Z axis is also possible if you build it right.
If you're going to try to print high temperature materials, you have to think about heating the enclosure and moving motors and electronics outside the enclosure. Belts are usually good to 85C, which is also about the maximum temperature for motors.
Re: thoughts on this design February 10, 2018 05:18PM |
Re: thoughts on this design February 10, 2018 06:41PM |
Re: thoughts on this design February 10, 2018 09:27PM |
Origamib
What sort of temperatures are you hoping to achieve in your chamber? If it is for ABS, you will likely be happy with 40-60c and I don't think the fabric will be necessary unless you want to make the chamber heater very efficient. If you are aiming for 60c+, then it will be a nice touch as it will also have the added effect of keeping the mechanics cool so they don't bind at the higher temperatures.
As for material, I'm sure anything will be fine as long as it can be folded and it will withstand constant movement. Perhaps you could sew the folds and then use a relatively still material? It may also want to be fireproof in case it comes apart and comes into contact with your hot end.
Re: thoughts on this design February 10, 2018 11:37PM |
Re: thoughts on this design February 11, 2018 02:29AM |
Re: thoughts on this design February 11, 2018 03:54AM |
Re: thoughts on this design February 11, 2018 09:17AM |
Re: thoughts on this design February 11, 2018 11:07AM |
Re: thoughts on this design February 11, 2018 12:21PM |
