Stepper kill ideas?
February 24, 2018 02:37AM
Im getting close to having my test rig finished. The purpose is to test various steppers and a couple different ball screw leads all while throwing around ballast on a linear rail at potentially very high speeds.I will be hand writing g-code to put the system through various cycles of speed and accelerations using different amounts of ballast.My concern is safety for myself and the components. If something doesnt go right and the carriage slams into the bearing blocks at 2-300mm/s it aint gonna be pretty. I need ideas on how to kill the thing instantaneously if thats even possible. if I put a switch at either end to kill the power it will take some time for the electronics to dicharge so that wont work. If I kill the power going from the stepper to the driver that might smoke the driver. Maybe thats the only way and that will have to be the result of an unexpected event. Any ideas?? Using Duet Ethernet to drive the whole thing on 24v
Re: Stepper kill ideas?
February 24, 2018 02:45AM
If you are not driving a bed heater from 24V then you can use a small 24V PSU, in which case the stepper motors will only move a small amount after you kill the power. Another possibility is to wire an external reset button to the expansion connector.
February 24, 2018 03:20AM
You put high Amp limit switches that will open the circuit to the motor coils and short circuit them (eventually through a low value resistor). The switches will suffer but braking effect guaranteed.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
February 24, 2018 10:13PM
dc42
David, I have one of these power supplies. [www.ebay.com] Can I use that for testing? I would set the current limit to just above the set current for the single stepper?
MKSA
"Braking" Damn good idea I do remember though reading in the Duet documentation that disconnecting the steppers while the board is under power could damage it. Is there a solution? whats the resistor for?
February 25, 2018 02:15AM
Yes you can use that PSU for testing, but keep the voltage output to 25V or below.
Disconnecting stepper motors while they are powered produces high voltages that arc across the contacts you are breaking, producing transients that are likely to damage the stepper drivers. In fact the modern Duets are fairly tolerant of it (see [m.youtube.com]) but we still advise against it.
February 25, 2018 02:47AM
Why not use a tennisball at the end of the rail?
If you only use Duet drivers the harm will be pretty small. External drivers with like 50V/10A, I'd be afraid off.
February 25, 2018 01:15PM
Bill Clark
dc42
MKSA
A low value resistor to dissipate the energy and limit the current.
A running motor is an alternator plus when you open the circuit, its inductance lead to high voltage spikes.
February 25, 2018 03:41PM
It's a faulty design if you can crash at high speeds. I'd put a limit switch in before your carriage can hit the end of its travel. You can test the distance it needs in the middle of the travel instead of the end.
February 25, 2018 04:28PM
Thanks guys. All great solutions. I'll post an action video once its operational
February 25, 2018 08:42PM
etfrench
its just a mechanism for testing. we are designing it now. lots of manual g-code input. wont be able engineer out my ability to potentially input something wrong
