I WANT A COOLING INSTEAD OF HEATED BED
Posted by swaroop
March 07, 2018 06:50AM
hi to all,
I want to use cooling bed instead of heated bed. I have a peltier to do but i have to control through marlin and ramps. please help me in this.
Thanks Swaroop
Re: I WANT A COOLING INSTEAD OF HEATED BED
March 07, 2018 07:38AM
HELLO,
Is it the same voltage rating? If so, just wire it the same way you would with the heated bed. Make sure you have a temperature sensor on the module.
What is the actual problem?
March 07, 2018 07:59AM
Hi Tleneel,
I placed peltier module as a cooling bed but when temperature given -4degree centigrade it is not responding and when i give high temperature its going low temperature. I want the temperature to be control or is there any where to invert the logic of mosfet like when the board is ON the D10 pins should give 12v
thanks
Swaroop
March 07, 2018 09:30AM
You could place the thermistor to the hot side of the Peltier and control it as usual. You wouldn't know exactly what temp the cold side is, but Peltiers efficiency is so lousy, you'll never reach -4°C anyway. Maybe 10° below ambient...
Make sure, the hot side is on a very large heatsink with fan.
March 08, 2018 05:36AM
Hi O_lampe,
Thanks for the suggestion but if i keep thermistor at hotter side where i can put the heat sink and fan? Please help in this!!
Thanks
Swaroop
March 09, 2018 01:51AM
Drill a small hole in the heatsink and mount the thermistor there..
March 09, 2018 05:13AM
ohh.. !! Thank you
