Hello there,
I recently build my first 3d printer and it came out ok. However i have issues with it. When I try to home it comes up halfway and stop. First I thought it maybe caused by delta_height setting so I doubled it and then it seems like it worked however it is double the distance between nozzle and the bed so it might cause scaling issues. Next I suspect that it might be caused by steps per mm calculation. however they are also correct. In addition to that only random two of my max endstops working correctly when I tried to double the distance. I check all by M119 command and each one of them worked. So at this point I am really confused and don't know what to do.
Hope you guys can help.
P.S: I am using Marlin 1.1.8 Firmware, if wanted I can add video and configuration.h file.
