Is there such a thing as a 3d printer that can print in any orientation?
For example, if the head had a wrist action to allow it to rotate, it could print sideways?
Alternatively if the print head was fixed so it was always pointing downwards and the bed/work piece had 4 or 5 axis of movement (as in a robot arm), you could print any direction instead of in flat layers.
You would then avoid the need for supports and in filling.
I wasn't sure if delta printers could do something like that?
No sure if such a thing exists?
