fan power on a 12v led power supply May 16, 2018 09:26AM |
Re: fan power on a 12v led power supply May 16, 2018 09:34AM |
Re: fan power on a 12v led power supply May 16, 2018 09:35AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: fan power on a 12v led power supply May 16, 2018 09:36AM |
Re: fan power on a 12v led power supply May 16, 2018 09:37AM |
Re: fan power on a 12v led power supply May 16, 2018 09:43AM |
Dust
Yes, its a crappy supply without a temperature sensor, so the fan is always on and just reponds to load a little.
See [www.youtube.com] for how to add in the sensor back in.
Re: fan power on a 12v led power supply May 16, 2018 09:48AM |
the_digital_dentist
My experience with those cheapo "LED" power supplies is that if the fan turns on, the supply is about to die. If the voltage is dropping and the fan is kicking on you're definitely overloading the supply.
the_digital_dentist
Look into a MeanWell power supply- not the fake MeanWells that littler ebay, but a real one that has safety certifications. They have protective circuits that actually keep the power supply from dying in the event of short, overloads, overheating, etc. They cost just a few $ more than the junk supplies.
If your controller board (and heaters) can handle 24V, use 24V, not 12V.
I have used LRS-200-24 fanless 24V power supplies in 2 printers and they're bullet proof. No fan, no noise.
Re: fan power on a 12v led power supply May 16, 2018 09:50AM |
Re: fan power on a 12v led power supply May 16, 2018 09:58AM |
dc42
That PSU obviously does have a temperature sensor for the fan, otherwise the fan voltage wouldn't vary with load the way it does. But it appears to be designed for use with an 18V fan, not a 12V fan. Are there any markings on the original fan that indicate its operating voltage?
Re: fan power on a 12v led power supply May 16, 2018 10:46AM |
Re: fan power on a 12v led power supply May 16, 2018 11:00AM |
Roberts_Clif
Most LED power supplies have a 12 Volt adjustment potentiometer. As shown in the Image below.
This should be adjusted to 12 volt. Higher voltages will allow ripple voltage under higher loads on the supply, this will in turn cause you nothing but greef.
Making you chase noise spikes causing many 3D Printer ghosts effects, the noise spikes on the controller voltage will cause you a most unpleasant 3D Printer experience.
My 12 volt 360 watt supply came pre-adjusted to 13.8 volts it took me what seemed forever and a oscilloscope to track down this problem.
Re: fan power on a 12v led power supply May 16, 2018 12:27PM |
Re: fan power on a 12v led power supply May 16, 2018 01:08PM |
Re: fan power on a 12v led power supply May 16, 2018 01:50PM |
