Advice Please - Tip jam into bed May 01, 2011 08:26AM |
Re: Advice Please - Tip jam into bed May 01, 2011 09:48AM |
Re: Advice Please - Tip jam into bed May 01, 2011 09:56AM |
Re: Advice Please - Tip jam into bed May 01, 2011 10:47AM |
Re: Advice Please - Tip jam into bed May 01, 2011 10:53AM |
Re: Advice Please - Tip jam into bed May 01, 2011 11:05AM |
Re: Advice Please - Tip jam into bed May 01, 2011 11:13AM |
Re: Advice Please - Tip jam into bed May 01, 2011 01:59PM |
Re: Advice Please - Tip jam into bed May 01, 2011 04:18PM |
Re: Advice Please - Tip jam into bed May 01, 2011 06:23PM |
Re: Advice Please - Tip jam into bed May 02, 2011 01:01AM |
Re: Advice Please - Tip jam into bed May 02, 2011 11:45AM |
Re: Advice Please - Tip jam into bed May 02, 2011 07:47PM |
3dtoolchain gcode tool
Check this box if you are using Volumetric Firmware
Start Speed for Z Movements (mm/min)
Max Speed for Z Movements (mm/min)
Amount to Shift the Part on the X Axis (mm)
Amount to Shift the Part on the Y Axis (mm)
Height to Start Printing at (mm)
Multiplyer to Scale the X Size By (% 1=100%)
Multiplyer to Scale the Y Size By (% 1=100%)
Multiplyer to Scale the Z Size By (% 1=100%)
Multiplyer to Scale the print speed by (% 1=100%)
Multiplyer to Scale the extrusion amount by (% 1=100%)
Speed to back off the filament at while moving without printing (mm/min)
Distance to back off the filament while moving without printing (mm)
Distance to return after backing off (mm)
Temperature to set the Tip to (°C)
Delay time to allow tip to come up to temperature (Seconds)
Temperature to set tip to after print is done (°C)
Speed multiplier for first layer (% 1=100%)
Enter number of this part to print (Integer)
Spacing center of part to center of part on X axis (mm)
Spacing center of part to center of part on Y axis (mm)
Re: Advice Please - Tip jam into bed May 05, 2011 08:06PM |
Re: Advice Please - Tip jam into bed May 05, 2011 10:40PM |
Re: Advice Please - Tip jam into bed May 05, 2011 11:09PM |
