need help making a hotbed controller work July 30, 2018 02:57PM |
Re: need help making a hotbed controller work July 31, 2018 12:23AM |
Re: need help making a hotbed controller work July 31, 2018 12:43AM |
Re: need help making a hotbed controller work July 31, 2018 12:46AM |
Re: need help making a hotbed controller work July 31, 2018 01:06AM |
Admin Registered: 15 years ago Posts: 7,319 |
Re: need help making a hotbed controller work July 31, 2018 03:26AM |
Dust
It plugs into your current bed output (ie 12v)
Re: need help making a hotbed controller work July 31, 2018 03:36AM |
No I would re-wire which is what I am doing as your analogy doesn't quite match up to my issue.Quote
the_digital_dentist
Here's something for you to meditate on: If the lights in your room are too dim, will changing the switch make them brighter?
Re: need help making a hotbed controller work July 31, 2018 05:31AM |
Re: need help making a hotbed controller work July 31, 2018 06:19AM |
Re: need help making a hotbed controller work July 31, 2018 07:48AM |
Re: need help making a hotbed controller work July 31, 2018 11:03AM |
Re: need help making a hotbed controller work July 31, 2018 11:06AM |
the_digital_dentist
Controllers and outboard switches are nice, but they don't make the bed get any hotter (just like changing the switches won't make that dimly lit room any brighter).
Still now it's on my "maybe list"
it's the PCB red plate and now I wonder if I have it upside down.. |
Re: need help making a hotbed controller work July 31, 2018 11:12PM |
Re: need help making a hotbed controller work August 01, 2018 03:51AM |
Dust
Also if your using a separate power supply, and it has a variable output, crank the voltage up.
Most cheap power supplies have a little variable resistor near the screw terminals. I tend to set these to 13.5v It makes a huge difference
Re: need help making a hotbed controller work August 01, 2018 06:44AM |
