Marlin Firmware for ramps 1.4 using TB6600
February 17, 2019 06:20AM
I'm using TB6600 for 3D printing machine: Dual X. But, I have some problem with TB6600 driver and Marlin Firmware. My error is shown in the picture. Can you help me fix this?
open | download - 52143696_10214072271746146_3775478322805342208_n (1).jpg (47.9 KB)
Re: Marlin Firmware for ramps 1.4 using TB6600
February 20, 2019 06:13PM
Marlin 1.1.9 and Above support TB6600 simply by adding enabling the line and changing the default to your choose of TB6600
* Options: A4988, A5984, DRV8825, LV8729, L6470, TB6560, TB6600, TMC2100,
* TMC2130, TMC2130_STANDALONE, TMC2208, TMC2208_STANDALONE,
* TMC26X, TMC26X_STANDALONE, TMC2660, TMC2660_STANDALONE,
* TMC5130, TMC5130_STANDALONE
#define X_DRIVER_TYPE A4988
February 21, 2019 08:16AM
i did this & nothing changing
& thank you for helping
open | download - Untitled.png (11 KB)
February 21, 2019 09:28AM
Further Explain the Problem you are having with the TB6600 Steppers
Do they turn, are they shaking back and forth, do they have holding torque ect......
February 21, 2019 10:12AM
everything is good ,but the shifting in y & x axises after complete each layer not rondom
and i print with 10% from its speed
and taut the belt very well
and the mechanical system is so good
February 21, 2019 01:37PM
Try connecting your X dual stepper motors in series.
February 22, 2019 10:11AM
I'm sorry how I can do that
February 22, 2019 10:38AM
To connect 2 steppers in series:
Take the 4 wires on your control board, they are A+ A- B- B+
Control board A+ goes to motor 1 A+
Motor 1 A- goes to motor 2 A+
Motor 2 A- goes to control board A-
Control Board B- goes to motor 1 B-
Motor 1 B+ goes to motor 2 B-
Motor 2 B+ goes to control board B+
In this way, the amount of current driven by your stepper drivers goes through both motors. The effective resistance is doubled, so you need more voltage to do it, but stepper drivers are current limited. As long as you have enough voltage at your PSU, it will work fine.
RAMPS 1.4 boards generally have 2 Z driver outputs, which are in parallel, so you need to drive double the current in order to drive 2 motors. If you set them up to drive 800mA, then each motor gets (about) 400mA
Duet Wifi boards have 2 Z drive connections, too, but they are in series (As described above) so they need jumpers to short the second motor or else the one motor doesn't work. If you tell it to drive the motor at 800mA, then both motors will get 800mA.
MBot3D Printer
MakerBot clone Kit from Amazon
Added heated bed.
Leadscrew self-built printer (in progress)
Duet Wifi, Precision Piezo parts
