Power supplies in series February 17, 2019 12:32PM |
Re: Power supplies in series February 17, 2019 01:34PM |
Re: Power supplies in series February 17, 2019 07:45PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Power supplies in series February 17, 2019 08:50PM |
Re: Power supplies in series February 17, 2019 09:15PM |
Re: Power supplies in series February 17, 2019 09:27PM |
Re: Power supplies in series February 18, 2019 10:04PM |
Re: Power supplies in series February 18, 2019 10:38PM |
According to reprap wiki : "Turn off your printer completely, and measure the resistance of your heatbed using a multimeter: it should not be higher than 1.2 Ohm. If it is higher than 1.2 Ohm, your heatbed will not get enough current and will not dissipate enough heat to reach the required temperatures."
Re: Power supplies in series February 20, 2019 03:07AM |
Re: Power supplies in series February 20, 2019 07:23AM |
Roberts_Clif
As the power supplies you are using have a isolated frame and neutral ground, further isolating output ground from AC Ground.
Re: Power supplies in series February 20, 2019 07:37AM |
Re: Power supplies in series February 20, 2019 07:40AM |
Re: Power supplies in series February 20, 2019 07:55AM |
Re: Power supplies in series February 23, 2019 04:34AM |
