Printer won't print June 14, 2011 09:49PM |
Re: Printer won't print June 14, 2011 09:52PM |
Re: Printer won't print June 14, 2011 10:18PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Printer won't print June 15, 2011 04:05AM |
Re: Printer won't print June 15, 2011 07:39AM |
Re: Printer won't print June 15, 2011 08:25AM |
140 ; GCode generated by RepSnapper by Kulitorum
G21 ;metric is good!
G90 ;absolute positioning
T0 ;select new extruder
G28 ;go home
G92 E0 ;set extruder home
M104 S73.0 ;set temperature
G1 X20 Y20 F500 ;Move away from 0.0, so we use the same reset (in the layer code) for each layer
G1 F20
G1 Z0 E0 F20
G1 F2300
G1 X12.7444 Y11.5736 F2300
G1 X13.1471 Y11.3046 E0.484241 F2300
G1 X14.0702 Y12.3693 E1.89347 F2300
G1 X16.3623 Y11.9134 E4.23043 F2300
G1 X16.8076 Y10.5764 E5.63965 F2300
G1 X17.2826 Y10.6709 E6.1239 F2300
G1 X17.1824 Y12.0766 E7.53312 F2300
G21 (set units to mm)
G90 (set positioning to absolute)
M108 R1.98 (set extruder speed)
M103 (Make sure extruder is off)
M104 S225 T0 (set extruder temperature)
M109 S125 T0 (set heated-build-platform temperature)
G162 Z F500 (home Z axis maximum)
G92 Z10 (set Z to 0)
G1 Z0.0 (move z down 10)
G162 Z F100 (home Z axis maximum)
G161 X Y F2500 (home XY axes minimum)
M132 X Y Z A B (Recall stored home offsets for XYZAB axis)
G1 X52.0 Y-57.0 Z10.0 F3300.0 (move to waiting position)
M6 T0 (wait for toolhead parts, nozzle, HBP, etc., to reach temperature)
M101 (Extruder on, forward)
G04 P5000 (Wait t/1000 seconds)
M103 (Extruder off)
G90
G21
M103
M105
M106
M140 S60.0
M141 S30.0
M142 S0.0
;M113 S1.0
M108 R1.566
M104 S220.0
M104 S218.099
M104 S195.0
G1 X4.12 Y2.83 Z0.17 F60.0
M101
G1 X4.37 Y2.66 Z0.17 F1800.0
G1 X6.2 Y2.29 Z0.17 F1800.0
G1 X7.19 Y2.49 Z0.17 F1800.0
G1 X8.37 Y3.28 Z0.17 F1800.0
G1 X8.13 Y3.64 Z0.17 F1800.0
G1 X3.95 Y3.64 Z0.17 F1800.0
G1 X3.82 Y3.2 Z0.17 F1800.0
M103
G1 X4.11 Y8.32 Z0.17 F2400.0
Re: Printer won't print June 15, 2011 10:11AM |
Re: Printer won't print June 15, 2011 02:09PM |
Re: Printer won't print June 15, 2011 02:41PM |
Re: Printer won't print June 15, 2011 03:05PM |
Re: Printer won't print June 15, 2011 04:57PM |
Re: Printer won't print June 16, 2011 07:47PM |
Re: Printer won't print June 16, 2011 08:49PM |
Re: Printer won't print June 16, 2011 09:09PM |
Re: Printer won't print June 16, 2011 09:34PM |
Re: Printer won't print June 18, 2011 11:36AM |
Re: Printer won't print June 22, 2011 12:48PM |
Re: Printer won't print June 22, 2011 02:13PM |
Re: Printer won't print June 22, 2011 10:33PM |
Re: Printer won't print June 22, 2011 11:10PM |
Re: Printer won't print June 23, 2011 06:12PM |
Re: Printer won't print June 24, 2011 07:54PM |
Re: Printer won't print June 24, 2011 08:15PM |
Re: Printer won't print June 24, 2011 08:18PM |
Re: Printer won't print June 24, 2011 08:39PM |
Re: Printer won't print June 24, 2011 08:43PM |
drive-pulley_3off.gcode
G21 (set units to mm) good
G90 (set positioning to absolute) good
M108 R1.98 (set extruder speed) Don't need and can be removed via replace.csv or left
M104 S225 T0 (set extruder temperature) good
G162 Z F500 (home Z axis maximum) Start of weird
G92 Z10 (set Z to 0) Zero should not be at the top (ok if the endstops are backwards)
G1 Z0.0 (move z down 10) Already set to zero so does not make sense
G162 Z F100 (home Z axis maximum) Already done once
G161 X Y F2500 (home XY axes minimum) good
M132 X Y Z A B (Recall stored home offsets for XYZAB axis) Not sure what this does and if your firmware supports it
G1 X52.0 Y-57.0 Z10.0 F3300.0 (move to waiting position) Most likely should be approx 100 by 100 for mendel
M6 T0 (wait for toolhead parts, nozzle, HBP, etc., to reach temperature) NO IDEA WHAT THIS IS [reprap.org]
M101 (Extruder on, forward) Don't need and can be removed via replace.csv or left
G04 P5000 (Wait t/1000 seconds) Not really needed in most cases
M103 (Extruder off) Don't need and can be removed via replace.csv or left
Re: Printer won't print June 24, 2011 08:46PM |
Re: Printer won't print June 24, 2011 08:52PM |
Re: Printer won't print June 24, 2011 09:29PM |
Re: Printer won't print June 24, 2011 09:58PM |
