[SOLVED] Axis moving only in one direction? September 10, 2020 01:55PM |
Re: Axis moving only in one direction? September 10, 2020 02:08PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Axis moving only in one direction? September 11, 2020 11:49AM |
Re: Axis moving only in one direction? September 11, 2020 02:46PM |
mardy3d
Thank you for your help! I just fixed it.
Good that you pointed me towards potential wiring issues! The connection of the end stop came loose and constantly indicated that it was hit. Hence, the RAMPS firmware did not allow motion in the negative y direction.
After reconnecting the pin, the end stop behaved correctly and everything moves as it should!
Hence, the problem is solved!
Good to hear you figured it out. Happy printing!
Re: Axis moving only in one direction? September 11, 2020 02:47PM |
