Unopened Filament shelf life?
Posted by aamcle
June 13, 2023 05:41PM
I have an unopened role of ABS I was given some years ago and I doubt it was new then. Posibly 5+ years old.
If I dry it will it still be usable?
Thanks aamcle
Re: Unopened Filament shelf life?
June 14, 2023 12:47AM
Probably fine, if it's been kept covered up. UV light can degrade ABS, but water typically not a problem. It doesn't absorb water much if at all.
It depends what you mean by "unopened", it might be a little dusty. You can get dust wipes as printable parts.
PLA and other filaments do absorb water.
June 14, 2023 01:21AM
should have a desiccant pack in the package to, so that helps.
June 14, 2023 08:25AM
The thing with a "best by" date is that it's always a minimum. It is not in Corporate Interest to make them accurate and reduce demand for a product.
Out of UV light, ABS can last for hundreds of years. The GTP is rarely a problem, unless it's been stored over an engine block or somewhere else that's constantly over 100 centigrade.
EDIT: I misread your post. I think I need some new spectacles.
Edited 2 time(s). Last edit at 06/14/2023 08:29AM by DragonFire.
