Learning gCode?
Posted by aamcle
Learning gCode?
September 06, 2023 09:48AM
Afternoon All.
I would like to learn gCode the conditional stuff not just move from A to B and I'm a little nervous of trying out on my printer although that might be the only way to do it.
There seem to be a number of videos, what resources wold you recommend?
Many Thanks aamcle
Re: Learning gCode?
September 06, 2023 10:06AM
[marlinfw.org]
And look into building the marlin simulator (read through [github.com])
Re: Learning gCode?
September 07, 2023 08:42AM
Conditional GCode is not a standard part of GCode. There are several different versions of it. Which version you have (if any) depends on what firmware you are running. For example:
RepRapFirmware: [docs.duet3d.com]
LinuxCNC: [linuxcnc.org]
VDX
Re: Learning gCode?
September 07, 2023 08:50AM
... if you are halfway experienced in programming, then you can modify existing or even create new g-codes or "macros" by implementing them into the parser (firmware) - it's not this hard to do ...
Edited 1 time(s). Last edit at 09/07/2023 08:51AM by VDX.
Viktor
Re: Learning gCode?
November 05, 2023 12:01PM
Hi, thank you for your suggestion, it helps me too.
Tutuapp
Edited 1 time(s). Last edit at 11/06/2023 09:56AM by ritawong30.
