GRBL to Reprap converter
Posted by aytact
September 08, 2023 07:41AM
Is there any software which converts grbl to reprap gcode.
I have a laser machine which uses Duet3, but lightburn producing grbl compatible code.
If you know any application which converts could you share please?
Or could you suggest any application which I can use instead of lightburn.
Thank you
Edited 1 time(s). Last edit at 09/08/2023 08:01AM by aytact.
VDX
Re: GRBL to Reprap converter
September 08, 2023 08:13AM
... first check the differences between your "brand" of GRBL and too, your "brand" of G-code ... it's mostly identical (same basics), but could differ in special M-codes and "newly added" G-codes for e.g. bed-levelling or such.
If there are only minor differences, then you can script your own "translator" without problems ... or even do this manually in a text editor by replacing/adding the specific sequences ...
Viktor
September 08, 2023 08:16AM
create the device manually and selecting Marlin instead of GRBL-M3., will probably be closer than grbl..
[docs.lightburnsoftware.com]
Edited 1 time(s). Last edit at 09/08/2023 08:17AM by Dust.
September 09, 2023 03:26AM
Lighrburn and Duet/RepRapFirmware do work together. Configure Lightburn to generate G1 moves with the S parameter controlling laser power (this is also the configuration used by Smoothieware). If it's a laser engraver then in RRF 3.5 you can use up to 8 values in the S parameter of a single G1 command.
