I have a Tevo Flash printer, that I have had for a few years. The machine worked flawlessly. I stopped using it for about 1 year. I started up again recently, but I notice that the machine does not follow my Start G-code that is listed in the Cura box. (Although it used to perfectly) I use to run ver 4.5.0 back then, but now that I have upgraded to 5.6.0 the problem has appeared. I am not sure what would be causing this to happen. My original Start G-code is displayed in the box, but the machine seems to follow it's own start code. It performs the BL-Touch routine like it did before, and then travels to the edge of the hot bed and overshoots it a bit and then purges the plastic to the ground. It never did this before.
Any Ideas ? Is this a bug in Cura. Like I said all I did was upgrade to Cura 5.6.0.
Thanks,
TT
