thermistor calibration
Posted by ag123
April 30, 2024 12:40PM
ok I understand that this topic is as ancient as 3d printing itself, in fact a thread surfaced years back
[forum.prusa3d.com]
Now here is the motivations:
If you simply go to the "online flea markets" e.g. a simple search for a thermistor returns all of them claiming '3950' thermistors with *no specs*
[www.aliexpress.com]
no doubt they are cheap, but my own experience suggest that I've once got a (hotend) thermistor that measures 50k at room temperature (25 deg C) for what is a 100k thermistor, even with all that 'beta' calculations, I can't get a 50k value for a 100k 3950 thermistor at that temperature, it is possibly off by a scale of 50% against freezing to boiling
[www.ametherm.com]
Then comes the idea that if I can get an accurate reference, e.g. a semiconductor temperature sensor (some of them are pretty accurate) e.g. but not limited to
[www.ti.com]
I can probably calibrate those unspecified thermistors against the Steinhart–Hart equation
[en.wikipedia.org]
Then comes the 'million dollar question':
supposing that calibrating room-100 deg C is feasible, and hence I can try to fit the values against Steinhart–Hart equation or Beta equation up to boiling point.
Now for the hotend thermistor, can we do *without* calibrating *hotend temperatures* which is more like 200 C - 250 C?
i.e. fit the Steinhart–Hart equation between room to boiling and use that equation for *hotend temperatures* that is *double* and higher than boiling point?
VDX
Re: thermistor calibration
April 30, 2024 02:42PM
... I've done some temp. sensor development with PT100, PT1000 and Ni200, where the sensing target range was between 0°C to 1000°C -- is pretty easy, when the curve is nearly linear, as with the PT sensors ...
Viktor
May 01, 2024 02:03AM
@VDX thanks much for your response,
I'd think PT100 is probably a good idea for a reference at least.
A difficulty I still confront is that it isn't easy to find a suitable liquid to do high temperature calibration from 100-250 deg C.
from room temperature to boiling is 'relatively easy' to do in a lab
VDX
May 01, 2024 03:56AM
... you can try with fluid metal with a low melting temp.
Viktor
May 01, 2024 04:37AM
just found out that a lot of 'cheap' PT100 are probably not platinium
more likely those are nickel
[datasheet.octopart.com]
[www.isabellenhuette.de]
those can probably still be used as some form of PTC thermistor
but that the coefficients and graphs are different, some are probably an attempt to replace the platinum PT100, not likely to be the same thing
VDX
May 01, 2024 05:16AM
... so more like hiding the fact that they're knock-offs?
With my knowledge nickel-sensors are named "NI(xxx)" for nickel ... and "PT" is meant for platinum eye rolling smiley
Viktor
