I am wondering here that is the bottom plate size important?
It seems to me that the size could be a bit bigger, or is it just a weight thing?
Also in my opinion, the bottom slide rods should be placed wider -> more accurate movement?
and to improve rigidity in the middle, there should be one threaded rod more between those sliding rods, just below/beside the belt that moves the bed.
The material on the bottom plate seems to be MDF, propably going to use Laminate flooring on my build, its quite light, and has a very hard surface. MDF from inside though.
Just thinking aloud here
No offense to anyone. I am currently building my first Prusa and these ideas just have come up while building.
