top and bottom print plate material
September 21, 2011 01:02PM
Hello all,
I was wondering what suggestions people have for a tom and bottom print plate material, the visual prusa build instructions show some kind of wood, but as far as I have seen it is never referenced what kind to use, the BOM just says Thick Sheet. I am certain I am overlooking this information somewhere... any help?
Re: top and bottom print plate material
September 21, 2011 01:55PM
Hi, I asked the same kind of question in this thread [forums.reprap.org] and was basically advised to use Dibond Aluminium. Mines not setup as yet though I used this company to get the material [www.cutplasticsheeting.co.uk] I hope this helps! smiling smiley
September 21, 2011 02:24PM
This should give you some ideas.
Wildseyed is a member here and might pop
in to give more info.
__________________________________________________________________________
"I like to be, what I like to see, in you and me.
I am the Stallion, Mang."
ISTAR Scope Club
September 21, 2011 03:29PM
I did the bottom plate out of plywood, and the top plate out of aluminum sheet covered in Kapton. Both were 1/8 in thick. You don't want the bottom plate to be a heat conductive material, and you want the top plate to be as conductive as possible. Aside from that, the top plate needs to have a surface that your plastic of choice will stick to. There is much discussion on this, bare glass works for PLA, Kaptop or PET tape works for ABS, and there are various other possibilities.
Edited 1 time(s). Last edit at 09/21/2011 03:30PM by jsadusk.
September 21, 2011 07:25PM
Has anyone found a good supplier of Dibond in the USA? I haven't been able to find one.
September 22, 2011 02:15AM
Why bother with Dibond? What advantage does it have over plain aluminum?
September 22, 2011 05:29AM
It's lighter but similar stiffness because it is a laminate with plastic in the middle. Also much easier to cut and drill.
September 22, 2011 01:50PM
if you are using a heated bed (PCB heated) wouldn't you want to use something non-conductive for your top plate? these instructions Here show wood of some kind. also, sort of a silly question, but if you use wood with a heated bed, wouldn't it slowly ruin the wood? I don't know much about the smoke point or what not of plywood or anything, wouldn't it start to discolor and wear?
September 22, 2011 04:44PM
You want the top plate thermally conductive, but yeah you're right, not electrically conductive. Kapton on the aluminum fixes that. Also I used nichrome instead of a PCB because I had it on hand, but same issues involved.
As for wood on the bottom, I actually put a thin layer of crack filler foam as an insulator between the nichrome and the bottom plate. I'm not sure if it was entirely necessary, but I'd seen people on the wiki do it, and it does appear plate heats up much faster with that insulation on the bottom.
