Re: Prusa Mendel i2 de spycom June 04, 2013 03:55PM |
Re: Prusa Mendel i2 de spycom June 05, 2013 05:18AM |
Re: Prusa Mendel i2 de spycom June 05, 2013 05:39AM |
#ifndef LANGUAGE_CHOICE #define LANGUAGE_CHOICE 3 // Pick your language from the list above #endif
>>>M119 SENDING:M119 Affichage du status des fin de course x_min: OUVERT y_min: OUVERT z_min: OUVERT
>>>M119 SENDING:M119 Affichage du status des fin de course x_min: DECLENCHE y_min: OUVERT z_min: OUVERT
// The position of the homing switches #define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops true //If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 190 #define X_MIN_POS 0 #define Y_MAX_POS 170 #define Y_MIN_POS 0 #define Z_MAX_POS 140 #define Z_MIN_POS 0 #define X_MAX_LENGTH 190 #define Y_MAX_LENGTH 170 #define Z_MAX_LENGTH 140
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
// corse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. const bool Y_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. const bool Z_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. #define DISABLE_MAX_ENDSTOPS // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders
Re: Prusa Mendel i2 de spycom June 05, 2013 05:27PM |
Re: Prusa Mendel i2 de spycom June 05, 2013 05:42PM |
Re: Prusa Mendel i2 de spycom June 06, 2013 06:24AM |
Re: Prusa Mendel i2 de spycom June 06, 2013 07:21AM |
Re: Prusa Mendel i2 de spycom June 06, 2013 10:23AM |
Re: Prusa Mendel i2 de spycom June 06, 2013 12:18PM |
Re: Prusa Mendel i2 de spycom June 06, 2013 12:50PM |
Re: Prusa Mendel i2 de spycom June 06, 2013 01:30PM |
Re: Prusa Mendel i2 de spycom June 06, 2013 01:51PM |
Re: Prusa Mendel i2 de spycom June 07, 2013 08:02AM |
Re: Prusa Mendel i2 de spycom June 07, 2013 11:26AM |
Re: Prusa Mendel i2 de spycom June 07, 2013 12:34PM |
Re: Prusa Mendel i2 de spycom June 07, 2013 12:39PM |
Re: Prusa Mendel i2 de spycom June 07, 2013 12:46PM |
Re: Prusa Mendel i2 de spycom June 08, 2013 07:04AM |
Re: Prusa Mendel i2 de spycom June 09, 2013 09:48AM |
Re: Prusa Mendel i2 de spycom June 09, 2013 11:20AM |
Re: Prusa Mendel i2 de spycom June 09, 2013 01:59PM |
Re: Prusa Mendel i2 de spycom June 10, 2013 11:24AM |
Re: Prusa Mendel i2 de spycom June 10, 2013 12:38PM |
Re: Prusa Mendel i2 de spycom June 10, 2013 03:28PM |
Re: Prusa Mendel i2 de spycom June 11, 2013 09:09AM |
Re: Prusa Mendel i2 de spycom June 11, 2013 10:53AM |
Re: Prusa Mendel i2 de spycom June 11, 2013 11:19AM |
Re: Prusa Mendel i2 de spycom June 11, 2013 12:19PM |
Imprimez le cube aux côté de 0.5mm d'épaisseur et assurez vous que les couches adhèrent bien, sans que la buse ne vienne pousser ou tirer le plastique déjà déposé durant l'impression.
Dans votre logiciel, ajustez la hauteur de couche par incréments de 0.01, jusqu'à ce que vous obteniez une belle impression.
Re: Prusa Mendel i2 de spycom June 11, 2013 04:53PM |
Re: Prusa Mendel i2 de spycom June 11, 2013 05:04PM |
