Reglages des steppers et mesure de voltage June 14, 2013 08:17AM |
Re: Reglages des steppers et mesure de voltage June 14, 2013 11:09AM |
Re: Reglages des steppers et mesure de voltage June 14, 2013 12:04PM |
Re: Reglages des steppers et mesure de voltage June 14, 2013 12:47PM |
Re: Reglages des steppers et mesure de voltage June 14, 2013 04:07PM |
Re: Reglages des steppers et mesure de voltage June 15, 2013 09:55AM |
Re: Reglages des steppers et mesure de voltage June 19, 2013 04:45PM |
Re: Reglages des steppers et mesure de voltage June 20, 2013 03:49AM |
Re: Reglages des steppers et mesure de voltage June 20, 2013 04:36AM |
Re: Reglages des steppers et mesure de voltage June 20, 2013 05:47AM |
Re: Reglages des steppers et mesure de voltage June 20, 2013 08:09AM |
Re: Reglages des steppers et mesure de voltage June 20, 2013 08:52AM |
Admin Registered: 13 years ago Posts: 2,569 |
Re: Reglages des steppers et mesure de voltage June 20, 2013 09:18AM |
Re: Reglages des steppers et mesure de voltage June 20, 2013 08:52PM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 05:02AM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 05:32AM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 05:35AM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 05:38AM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 05:40AM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 05:53AM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 07:09AM |
Re: Reglages des steppers et mesure de voltage June 21, 2013 06:15PM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2133.3333,96.43} // default steps per unit for ultimaker 200.0*8/3,760*1.1 #define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instanteneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Reglages des steppers et mesure de voltage June 26, 2013 01:13PM |
