erreur de compilation Arduino IDE et Sanguinololu v1.3a June 30, 2013 08:19PM |
In file included from arc_func.cpp:26:
/Sprinter.h:6:23: error: Arduino.h: No such file or directory
Sprinter.h:97: error: variable or field 'manage_inactivity' declared void
Sprinter.h:97: error: 'byte' was not declared in this scope
Sprinter.h:108: error: variable or field 'kill' declared void
Sprinter.h:108: error: 'byte' was not declared in this scope
#if defined(ARDUINO) && ARDUINO >= 100 #include "Arduino.h" #else #include #endifil me semble que ça ve dire qu'il cherche à charger Arduino.h au lieu de WProgram.h ce qui laisse penser que la valer ARDUINO est >=100.
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a June 30, 2013 10:08PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 01, 2013 11:18AM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 02, 2013 06:04AM |
Sprinter
11:45:47.776 : 1.3.17T / 04.05.2012
11:45:47.776 : start 11:45:47.776 : Soft PWM Init
11:45:47.776 : Planner Init 11:45:47.776 : Stepper Timer init
11:45:47.776 : Free Ram: 1116
11:45:47.776 : Plan Buffer Size:1152 / 16
11:45:56.897 : Unknown command:
11:45:56.897 : ?
11:45:59.978 : Unknown command:
11:45:59.978 : ?
11:46:12.199 : Unknown command:
11:46:12.199 : ?
11:46:21.372 : Unknown command:
11:46:45.833 : Unknown command:
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 03, 2013 07:52PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 03, 2013 09:32PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 03, 2013 10:12PM |
Firmware compilation and upload
5. Edit INSTALL_DIR inside Sprinter/Makefile (do not mind the default reference to arduino 0022)
6. Run make. If everything goes well Sprinter/applet/Sprinter.cpp should have been created.
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 05, 2013 08:19AM |
ensuite Repetier semble gelé avec une commande en attente.Quote
11:53:35.982 : N0 M110 *3
11:53:35.982 : N1 M115 *7
11:53:35.998 : N2 T0 *24
11:53:35.998 : N4 M111 S6 *67
11:53:38.525 : Sprinter
11:53:38.525 : 1.3.22T / 20.08.2012
11:53:38.556 : start
11:53:38.556 : Soft PWM Init
11:53:38.556 : Planner Init
11:53:38.556 : Stepper Timer init
11:53:38.556 : Free Ram: 1101
11:53:38.556 : Plan Buffer Size:1152 / 16
11:53:38.556 : N0 M110 *3
11:53:38.556 : N1 M115 *7
11:53:38.556 : N2 M111 S6 *69
11:53:47.682 : Unknown command:
11:53:47.682 : ?
11:53:47.698 : ok
11:53:50.755 : Unknown command:
11:53:50.755 : ?
11:53:50.755 : ok
11:54:02.986 : Unknown command:
11:54:02.986 : ?
11:54:02.986 : ok
11:54:12.159 : Unknown command:
11:54:12.159 : ok
11:54:36.620 : Unknown command:
11:54:36.620 : ok
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 05, 2013 10:50AM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 05, 2013 11:28AM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 05, 2013 07:29PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 06, 2013 03:56PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 06, 2013 04:28PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 07, 2013 12:13AM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 07, 2013 04:59AM |
//Implemented Codes //------------------- // G0 -> G1 // G1 - Coordinated Movement X Y Z E // G2 - CW ARC // G3 - CCW ARC // G4 - Dwell S or P // G10 - retract filament according to settings of M207 // G11 - retract recover filament according to settings of M208 // G28 - Home all Axis // G90 - Use Absolute Coordinates // G91 - Use Relative Coordinates // G92 - Set current position to cordinates given //RepRap M Codes // M0 - Unconditional stop - Wait for user to press a button on the LCD (Only if ULTRA_LCD is enabled) // M1 - Same as M0 // M104 - Set extruder target temp // M105 - Read current temp // M106 - Fan on // M107 - Fan off // M109 - Wait for extruder current temp to reach target temp. // M114 - Display current position //Custom M Codes // M17 - Enable/Power all stepper motors // M18 - Disable all stepper motors; same as M84 // M20 - List SD card // M21 - Init SD card // M22 - Release SD card // M23 - Select SD file (M23 filename.g) // M24 - Start/resume SD print // M25 - Pause SD print // M26 - Set SD position in bytes (M26 S12345) // M27 - Report SD print status // M28 - Start SD write (M28 filename.g) // M29 - Stop SD write // M30 - Delete file from SD (M30 filename.g) // M31 - Output time since last M109 or SD card start to serial // M42 - Change pin status via gcode Use M42 Px Sy to set pin x to value y, when omitting Px the onboard led will be used. // M80 - Turn on Power Supply // M81 - Turn off Power Supply // M82 - Set E codes absolute (default) // M83 - Set E codes relative while in Absolute Coordinates (G90) mode // M84 - Disable steppers until next move, // or use S to specify an inactivity timeout, after which the steppers will be disabled. S0 to disable the timeout. // M85 - Set inactivity shutdown timer with parameter S. To disable set zero (default) // M92 - Set axis_steps_per_unit - same syntax as G92 // M114 - Output current position to serial port // M115 - Capabilities string // M117 - display message // M119 - Output Endstop status to serial port // M140 - Set bed target temp // M190 - Wait for bed current temp to reach target temp. // M200 - Set filament diameter // M201 - Set max acceleration in units/s^2 for print moves (M201 X1000 Y1000) // M202 - Set max acceleration in units/s^2 for travel moves (M202 X1000 Y1000) Unused in Marlin!! // M203 - Set maximum feedrate that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec // M204 - Set default acceleration: S normal moves T filament only moves (M204 S3000 T7000) im mm/sec^2 also sets minimum segment time in ms (B20000) to prevent buffer underruns and M20 minimum feedrate // M205 - advanced settings: minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk, E=maximum E jerk // M206 - set additional homeing offset // M207 - set retract length S[positive mm] F[feedrate mm/sec] Z[additional zlift/hop] // M208 - set recover=unretract length S[positive mm surplus to the M207 S*] F[feedrate mm/sec] // M209 - S<1=true/0=false> enable automatic retract detect if the slicer did not support G10/11: every normal extrude-only move will be classified as retract depending on the direction. // M218 - set hotend offset (in mm): T X Y // M220 S- set speed factor override percentage // M221 S- set extrude factor override percentage // M240 - Trigger a camera to take a photograph // M300 - Play beepsound S P // M301 - Set PID parameters P I and D // M302 - Allow cold extrudes // M303 - PID relay autotune S sets the target temperature. (default target temperature = 150C) // M304 - Set bed PID parameters P I and D // M400 - Finish all moves // M500 - stores paramters in EEPROM // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. // M503 - print the current settings (from memory not from eeprom) // M540 - Use S[0|1] to enable or disable the stop SD card print on endstop hit (requires ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED) // M600 - Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal] // M907 - Set digital trimpot motor current using axis codes. // M908 - Control digital trimpot directly. // M350 - Set microstepping mode. // M351 - Toggle MS1 MS2 pins directly. // M928 - Start SD logging (M928 filename.g) - ended by M29 // M999 - Restart after being stopped by error
//Implemented Codes //------------------- // G0 -> G1 // G1 - Coordinated Movement X Y Z E // G2 - CW ARC // G3 - CCW ARC // G4 - Dwell S or P // G28 - Home all Axis // G90 - Use Absolute Coordinates // G91 - Use Relative Coordinates // G92 - Set current position to cordinates given //RepRap M Codes // M104 - Set extruder target temp // M105 - Read current temp // M106 - Fan on // M107 - Fan off // M109 - Wait for extruder current temp to reach target temp. // M114 - Display current position //Custom M Codes // M20 - List SD card // M21 - Init SD card // M22 - Release SD card // M23 - Select SD file (M23 filename.g) // M24 - Start/resume SD print // M25 - Pause SD print // M26 - Set SD position in bytes (M26 S12345) // M27 - Report SD print status // M28 - Start SD write (M28 filename.g) // M29 - Stop SD write // - - Delete file on sd card // M42 - Set output on free pins, on a non pwm pin (over pin 13 on an arduino mega) use S255 to turn it on and S0 to turn it off. Use P to decide the pin (M42 P23 S255) would turn pin 23 on // M80 - Turn on Power Supply // M81 - Turn off Power Supply // M82 - Set E codes absolute (default) // M83 - Set E codes relative while in Absolute Coordinates (G90) mode // M84 - Disable steppers until next move, // or use S to specify an inactivity timeout, after which the steppers will be disabled. S0 to disable the timeout. // M85 - Set inactivity shutdown timer with parameter S. To disable set zero (default) // M92 - Set axis_steps_per_unit - same syntax as G92 // M93 - Send axis_steps_per_unit // M115 - Capabilities string // M119 - Show Endstopper State // M140 - Set bed target temp // M190 - Wait for bed current temp to reach target temp. // M201 - Set maximum acceleration in units/s^2 for print moves (M201 X1000 Y1000) // M202 - Set maximum feedrate that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec // M203 - Set temperture monitor to Sx // M204 - Set default acceleration: S normal moves T filament only moves (M204 S3000 T7000) in mm/sec^2 // M205 - advanced settings: minimum travel speed S=while printing T=travel only, X=maximum xy jerk, Z=maximum Z jerk // M206 - set additional homing offset // M220 - set speed factor override percentage S=factor in percent // M221 - set extruder multiply factor S100 --> original Extrude Speed // M301 - Set PID parameters P I and D // M303 - PID relay autotune S sets the target temperature. (default target temperature = 150C) // M400 - Finish all moves // M500 - stores paramters in EEPROM // M501 - reads parameters from EEPROM (if you need to reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. // M503 - Print settings // Debug feature / Testing the PID for Hotend // M601 - Show Temp jitter from Extruder (min / max value from Hotend Temperature while printing) // M602 - Reset Temp jitter from Extruder (min / max val) --> Don't use it while Printing // M603 - Show Free Ram
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 07, 2013 08:20AM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 07, 2013 12:24PM |
résultat : Taille binaire du croquis : 47 720 octets (d'un max de 63 488 octets)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override this check.
résultat : Binary sketch size: 47214 bytes (of a 63488 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x8e
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude: stk500_getsync(): not in sync: resp=0x00
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 07, 2013 02:51PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 07, 2013 05:18PM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 08, 2013 03:56AM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a July 14, 2013 05:31AM |
Re: erreur de compilation Arduino IDE et Sanguinololu v1.3a August 21, 2013 10:04PM |
