Re: Hotend "AllinOne" April 05, 2015 12:12PM |
Re: Hotend "AllinOne" April 05, 2015 01:06PM |
Re: Hotend "AllinOne" April 05, 2015 01:16PM |
Jibeji
Non, la toute dernière version de Marlin téléchargée ce jour.
// 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is Mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // 11 is 100k beta 3950 1% thermistor (4.7k pullup) // 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed) // 13 is 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE" // 20 is the PT100 circuit found in the Ultimainboard V2.x // 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950 // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
Re: Hotend "AllinOne" April 05, 2015 01:22PM |
Re: Hotend "AllinOne" April 05, 2015 01:49PM |
fourmi
@elicend: Imprimes un extrudeur wade,ça ira trés bien .( Sauf que peut etre tu ne peux plus imprimé ?)
Re: Hotend "AllinOne" April 06, 2015 04:42AM |
Re: Hotend "AllinOne" April 06, 2015 04:47AM |
Re: Hotend "AllinOne" April 06, 2015 05:24AM |
Re: Hotend "AllinOne" April 06, 2015 05:47AM |
Jibeji
Voici l'extrudeur en question. (CNC reconvertie en imprimante 3D)
Re: Hotend "AllinOne" April 06, 2015 06:16AM |
Re: Hotend "AllinOne" April 08, 2015 10:20AM |
Re: Hotend "AllinOne" April 09, 2015 03:05AM |
Re: Hotend "AllinOne" April 09, 2015 03:51AM |
Re: Hotend "AllinOne" April 09, 2015 04:18AM |
Re: Hotend "AllinOne" April 09, 2015 09:56AM |
Re: Hotend "AllinOne" April 10, 2015 03:47PM |
merci pour votre aide à tous !!|
Re: Hotend "AllinOne" April 22, 2015 05:23PM |
Re: Hotend "AllinOne" April 23, 2015 04:24AM |
héhé.|
Re: Hotend "AllinOne" April 23, 2015 08:05AM |
Re: Hotend "AllinOne" April 23, 2015 01:41PM |
Re: Hotend "AllinOne" May 12, 2015 09:03AM |
Re: Hotend "AllinOne" May 12, 2015 10:07AM |
#define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
Re: Hotend "AllinOne" May 16, 2015 06:41PM |
Re: Hotend "AllinOne" May 17, 2015 03:08AM |
#define TEMP_SENSOR_0 13
Re: Hotend "AllinOne" May 17, 2015 06:12AM |
Re: Hotend "AllinOne" May 21, 2015 04:06PM |
Re: Hotend "AllinOne" May 22, 2015 02:15AM |
Re: Hotend "AllinOne" May 22, 2015 01:07PM |
// This defines the number of extruders
// :[1,2,3,4]
#define EXTRUDERS 1
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
Re: Hotend "AllinOne" May 23, 2015 05:55PM |
Re: Hotend "AllinOne" May 26, 2015 06:12AM |
