Re: Maximus : Imprimante format XL May 25, 2015 03:59AM |
[reprap.org]|
Re: Maximus : Imprimante format XL May 25, 2015 06:53AM |
Re: Maximus : Imprimante format XL May 25, 2015 08:51AM |
* R/C SERVO support
* Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
#define NUM_SERVOS 1 // Servo index starts with 0 for M280 command
// Servo Endstops
// This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes.
// Use M206 command to correct for switch height offset to actual nozzle height. Store that setting with M500.
#define SERVO_ENDSTOPS {-1, -1, 0} // Servo index for X, Y, Z. Disable with -1
#define SERVO_ENDSTOP_ANGLES {0,0, 0,0, 90,5} // X,Y,Z Axis Extend and Retract angles
#include "Configuration_adv.h"
#include "thermistortables.h"
#endif //__CONFIGURATION_H
Re: Maximus : Imprimante format XL May 25, 2015 11:24AM |
Re: Maximus : Imprimante format XL May 25, 2015 11:40AM |
Re: Maximus : Imprimante format XL May 25, 2015 01:26PM |
Re: Maximus : Imprimante format XL June 23, 2015 01:03AM |
Re: Maximus : Imprimante format XL June 23, 2015 01:41AM |
luis0301
bonjour je voudrais savoir ou l acheter et a conbien ,quant je vais sur le site celui ci et en maintenance
Re: Maximus : Imprimante format XL June 24, 2015 12:32AM |
luis0301
