Initialisation Imprimante problématique August 30, 2014 05:48AM |
//// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 1*60, 0} // set the homing speeds (mm/min) // #define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min) REPCHAB // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80.00,80.00,4000,735} // {78.7402,78.7402,200.0*8/3,760*1.1} REPCHAB default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {200,200,3.00,13} // {500, 500, 5, 25} REPCHAB // (mm/sec) #define DEFAULT_MAX_ACCELERATION {2000,2000,3,2000} // {9000,9000,100,10000} REPCHAB X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 2000 // 3000 REPCHAB X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 0 // 3000 REPCHABX, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Initialisation Imprimante problématique August 30, 2014 06:50AM |
Re: Initialisation Imprimante problématique August 30, 2014 08:03AM |
; generated by Slic3r 1.1.7 on 2014-08-30 at 13:54:07 ; perimeters extrusion width = 0.35mm ; infill extrusion width = 0.37mm ; solid infill extrusion width = 0.37mm ; top infill extrusion width = 0.37mm G21 ; set units to millimeters M104 S190 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle M109 S190 ; wait for temperature to be reached G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion M106 S255 G1 F1800.000 E-1.00000 G92 E0 G1 Z0.350 F7800.000 G1 X84.915 Y85.753 F7800.000
Re: Initialisation Imprimante problématique August 30, 2014 08:12AM |
G28 ; home all axes
G1 Z5 F120; lift nozzle
G92 E0
M106 S255
G92 E0
G1 Z0.350 F7800.000 => G1 Z0.350 F120
G1 E1.00000 F1800.000
Re: Initialisation Imprimante problématique August 30, 2014 08:46AM |
Re: Initialisation Imprimante problématique August 30, 2014 08:55AM |
Re: Initialisation Imprimante problématique August 30, 2014 09:00AM |
Re: Initialisation Imprimante problématique August 30, 2014 12:13PM |
Re: Initialisation Imprimante problématique August 30, 2014 12:42PM |
Re: Initialisation Imprimante problématique August 30, 2014 02:40PM |
Re: Initialisation Imprimante problématique August 30, 2014 04:31PM |
Re: Initialisation Imprimante problématique August 30, 2014 06:00PM |
Re: Initialisation Imprimante problématique August 31, 2014 03:10AM |
Re: Initialisation Imprimante problématique August 31, 2014 03:29AM |
Re: Initialisation Imprimante problématique August 31, 2014 04:28AM |
Re: Initialisation Imprimante problématique August 31, 2014 06:29AM |
Re: Initialisation Imprimante problématique August 31, 2014 07:39AM |
rchab
Bon ça progresse !
Maintenant l'impression de la pièce va bien jusqu'au bout sauf qu'il y a de la rétractation. La pièce est donc déformée.
Re: Initialisation Imprimante problématique August 31, 2014 09:17AM |
Re: Initialisation Imprimante problématique August 31, 2014 09:28AM |
Re: Initialisation Imprimante problématique August 31, 2014 09:59AM |
Re: Initialisation Imprimante problématique August 31, 2014 10:52AM |
Re: Initialisation Imprimante problématique August 31, 2014 12:03PM |
Re: Initialisation Imprimante problématique August 31, 2014 06:58PM |
Re: Initialisation Imprimante problématique September 01, 2014 02:57AM |
