Commande M503 message cde non supporté Eprom non compilé October 29, 2015 12:18PM |
Re: Commande M503 message cde non supporté Eprom non compilé October 29, 2015 01:33PM |
#define EEPROM_SETTINGS #define EEPROM_CHITCHAT
Re: Commande M503 message cde non supporté Eprom non compilé October 29, 2015 01:40PM |
Re: Commande M503 message cde non supporté Eprom non compilé October 30, 2015 07:10AM |
DD/DD2-Extruder At firmware version 2.x the DD2-Extruder is configured by default. The difference is only made at the stepping calculation. Please find below the values to set at the Configuration.h for both extruders: DD2-Extruder #define EXT0_STEPS_PER_MM 130 respectively #define EXT1_STEPS_PER_MM 130 DD-Extruder (deprecated) #define EXT0_STEPS_PER_MM 110 respectively #define EXT1_STEPS_PER_MM 110
Re: Commande M503 message cde non supporté Eprom non compilé October 30, 2015 08:50AM |
#define EEPROM_MODE 0
Re: Commande M503 message cde non supporté Eprom non compilé October 30, 2015 09:42AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 30, 2015 10:16AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 30, 2015 11:08AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 30, 2015 11:34AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 05:34AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 08:07AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 08:39AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 09:32AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 10:01AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 10:13AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 10:26AM |
À la différence d'une mémoire PROM qui ne peut être programmée qu'une seule fois, une mémoire EEPROM peut être effacée et reprogrammée plusieurs fois (de 100 000 à 1 000 000 de fois) et peut être lue à l'infini.
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 11:10AM |
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 11:56AM |
normalQuote
Malheureusement, je dirai non. Si tu repasses en #define EEPROM_MODE 0, tu va utiliser les valeurs du dernier configuration.h que tu as envoyé, et pas celui qui est actuellement dans la memoire de ta carte.
Re: Commande M503 message cde non supporté Eprom non compilé October 31, 2015 03:26PM |
