New Pronterface
February 03, 2012 04:41PM
The newest Kliment/Printrun e5b0a4f just makes a dead stop after the last gcode is issued. The earlier version returned the head near to home. What do I need to do to activate the latest version to behave like the earlier version?
Re: New Pronterface
February 04, 2012 04:47AM
Neither one will fix the problem it is your gcode generator that you need to change!
If you are using Printrun then perhaps you are using Skeinforge to generate your gcode in which case the command would be in your end.code file.
My end.gclode is the following:
G91 ;set relative positioning
G1 F50 ;set move speed to suit Z-axes
G1 Z5 F50 ;move up 5mm from the finished object
G90 ;set absolute positioning
G1 F2300 ;set move speed to suit XY-axes
G1 X100 Y200 F2300 ;move table out to remove object
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
Re: New Pronterface
February 04, 2012 10:35AM
Thank you rhmorrison,
When the print starts, the head moves to the center of the printbed very slowly F60. Is there an adjustment for that somewhere?
Edited 1 time(s). Last edit at 02/04/2012 12:10PM by librav.
Re: New Pronterface
February 07, 2012 04:15PM
I believe that is on the limit tab if you're using skeinforge, turn it off. The head will move to start much faster now.
Re: New Pronterface
February 09, 2012 05:48AM
Do NOT turn off limit unless the firmware you are using does this automatically!
Sprinter is supposed to have "movement speed control" so it might be OK.
In any case, there is a place to put the initial speed. This you can set to 30mm/s or 50mm/s.
Then you don't have the problem at the start of the print.
Bob Morrison
