Possible fix of comms delay bug June 08, 2008 08:38PM |
Re: Possible fix of comms delay bug June 09, 2008 03:57AM |
Anonymous User
Re: Possible fix of comms delay bug June 09, 2008 06:53AM |
Anonymous User
Re: Possible fix of comms delay bug June 09, 2008 11:52AM |
Re: Possible fix of comms delay bug June 09, 2008 12:37PM |
Re: Possible fix of comms delay bug June 09, 2008 04:44PM |
Sheesh, FUD time again I see. The minor garbage collections are only a couple of microseconds long, so they don't count. The major collections can take a couple of seconds. If this is problematic you give the jvm this option: -XX:-UseConcMarkSweepGC and the problem goes away. It uses a bit more cpu which is why it isn't enabled by default. Next time read the Java manuals before spouting garbage.
The reason EMC needs the Real Time Kernel is that it is directly pulsing the steppers. If it was simply providing a stream of motion data that was interpreted later it wouldn't need the RT stuff. Of course, it also wouldn't be able to do all the cool stuff it does...
Re: Possible fix of comms delay bug June 09, 2008 05:15PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Possible fix of comms delay bug June 09, 2008 05:39PM |
