sid
the ReRap host made portable
October 16, 2008 11:55AM
All the hassle installing Java and the additional libraries needed to run the reprap host on a windows computer made me think about making everything portable, and thanks to jsmooth I think I've succeeded.
Tested on three different machines (all windows xp with no sp, sp1 and sp2, none of wich has any java jre or jdk installed)
All you have to do is unpack in desired folder (or usb stick) and run the reprap_bundled.exe from the reprap folder.
you may edit the batch file if you want to start the host with options
(I didn't, so you're on your own for now)
I also added ReplicatorG with edited JAVA_HOME in the batch file to use the same java directory as the rrhost.
tell me what you think
ReplicatorG 0001 & reprap host 20080523
filesize: 37 MB
filetype: rar
unpacked: 139 MB (thanks to java winking smiley)
[rapidshare.com]
'sid
Edited 1 time(s). Last edit at 10/22/2008 07:18PM by sid.
VDX
Re: the ReRap host made portable
October 16, 2008 04:20PM
Hi sid,
... great job!
I downloaded it and run the host and the replicatorC on my DualCore-desktop with Vista - the host could import and display a STL-object, next days i'll play around a bit with repG winking smiley
Viktor
October 20, 2008 01:47PM
Ah, that's nice work Sid! I'll check it out when I get home.
Demented
sid
October 22, 2008 07:19PM
Since there's a new verision of replicatorG I just added the version numbers above.
As soon as the reprap host gets a new update The package will be updated too
'sid
PS yes, I know, a new host is out, but not in a stable compiled package.. so hang on!
Edited 2 time(s). Last edit at 11/22/2008 12:18PM by sid.
December 09, 2008 04:30PM
Appears to be running fine on my Vista laptop, no reprap attatched at the moment though.
-Matt
