I've just started using the latest java based host software because my firmware can't handle the old g-Codes (M101-103 and M108). I like to use this firmware because it is Adrian's main branch and it uses interrupts for timing and has neat acceleration capabilities. The ever lasting dilemma between stability and progress
Using the latest host software, the outline is not being printed.
This is my configuration (see attachment). It also happens with a configuration with only 1 extruder configured.
Last Changed Author: adrian-bowyer
Last Changed Rev: 3146
Last Changed Date: 2009-06-12 15:46:28 +0200 (Fri, 12 Jun 2009
Anyone else had this problem? Any java-host exports who know which property/setting I should look for?
Thanks!
Regards,
Erik de Bruijn
Ultimaker.com] - [
blog.erikdebruijn.nl]
