I have a Magnetic encoder DIP extruder motor, but I think skeinforge is not making full use of it.
From what I observe, the flowrate is back-calculated by the maximum feedrate and that's it. That's ok because the machine is ultimately feedrate bound, but when printing the raft-base, the speed is limited by the flow rate, and even my machine is capable at higher flowrate, it doesn't go up. The very same flow rate is used through out the process.
I could imagine changing flow rate in upper printing layer might causes issues because the extrusion rate might not response immediately due to compression of plastics. However, it should be doable to use a different flow rate for the raft.
I think this could be a huge time saver. I bet it wasn't done because not many people has flowrate controlled motor? Or is there any other blocking issue that I don't expect?
