RepRap host under windows XP December 08, 2010 02:12AM |
C:\reprap>"C:\Program Files\Java\jre6\bin\java.exe" -cp ".\reprap.jar;.\RXTXcomm.jar;.\j3dcore.jar;.\j3d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3.jar;.\vecmath.jar;." -Xmx1024M org/reprap/Main DEBUG: The distribution preferences file and yours match. This is good. [0.000s/-1291791987968ms] DEBUG: GCode opening port COM8 [0.125s/125ms] Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 DEBUG: Attempting to initialize Arduino/Sanguino [5.453s/5328ms] # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x695cc30d, pid=3960, tid=2908 # # JRE version: 6.0_22-b04 # Java VM: Java HotSpot(TM) Client VM (17.1-b03 mixed mode windows-x86 ) # Problematic frame: # C [nvoglnt.dll+0xcc30d] # # An error report file with more information is saved as: # C:\reprap\hs_err_pid3960.log # # If you would like to submit a bug report, please visit: # [java.sun.com] # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # C:\reprap>if ERRORLEVEL 1 pause Press any key to continue . . .
Re: RepRap host under windows XP December 08, 2010 04:50AM |
Re: RepRap host under windows XP December 08, 2010 05:10AM |
Re: RepRap host under windows XP January 03, 2011 11:20AM |
Re: RepRap host under windows XP January 03, 2011 12:43PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: RepRap host under windows XP January 03, 2011 01:19PM |
