Need help for Host installation hot smiley
July 26, 2011 07:28PM
Hello,
I'm french, and try to comme in the RepRap World!
I'm trying to install RepRap Host. The soft run (the two windows on screen), then crash.
See the picture of the dos window and the log file of the crash in attachment.
Could you help me?
Best regards,
Tarz (Reunion Island)
open | download - Host Crash.gif (22.9 KB)
open | download - hs_err_pid1112.log (14.4 KB)
VDX
Re: Need help for Host installation hot smiley
July 27, 2011 03:38PM
... i can't see any Java relevant directories in your path variable - maybe you haven't installed Java correctly?
Viktor
July 27, 2011 06:48PM
Thank you Victor, I will try to re-install Java.
Renaud.
August 23, 2011 12:49AM
I also recall seeing there are known issues with RepRap and Java 6.. possible try using Java 1.5 instead of Java 1.6
actually its not a java problem.
The crash occured in the native (dll) java 3d libraries.
I would check that you your java 3d dll's match the version of the java3d jar you are using (check the paths in the crash log).
I would also look at up grading you graphics card drivers. These type of errors can sometimes be caused by a bad graphics driver.
